Mobile, Graphics, and Gaming blog Pixel Local Storage
  • pixel_local_storage
  • order_independent_transparency
  • Mali
  • unreal
  • epic
  • opengl_es_3.0
  • gpu
  • opengl_es
Pixel Local Storage
Marius Bjørge
Marius Bjørge
April 17, 2015
1 minute read time.
It's now been a year since we announced the Shader Pixel Local Storage extension. Here I'll recap what we've done since the time of the release.
What is Pixel Local Storage?
I recommend reading Jan-Harald Fredriksen's blog post Pixel Local Storage on ARM® Mali™ GPUs for background information about what Pixel Local Storage is and the advantages of exposing it.
Order Indepdendent Transparency
At SIGGRAPH 2014 we presented "Efficient Rendering with Tile Local Storage", with detailed use-cases mixing advanced techniques such as deferred shading and order independent transparency. The problem with transparency is that blending operations tend to be non-commutative, meaning that the end result is highly sensitive to the shading order of the blended fragments. Using Pixel Local Storage we implemented both a full depth-peeling approach and also compared that against approximate approaches such as Multi-Layer Alpha Blending and Adaptive Range blending. Not only that; we implemented all of this very efficiently on-top of a fully deferred shading renderer. Please see Efficient Rendering with Tile Local Storage for more details.
Collaboration with Epic
We integrated Pixel Local Storage into Epic's Unreal Engine 4. This enabled more efficient HDR rendering as well as features such as bloom and soft particles.
Sample code
We've also release a couple of samples showing how to use Pixel Local Storage in your own code.
This sample implements deferred shading using pixel local storage.
http://malideveloper.arm.com/develop-for-mali/sample-code/shader-pixel-local-storage-sample/
Translucency
This sample uses Pixel Local Storage to render translucent geometry.
http://malideveloper.arm.com/downloads/deved/tutorial/SDK/android/2.0/translucency.html
References
  1. Pixel Local Storage on ARM® Mali™ GPUs
  2. Supporting the development of mobile games at GDC 2015
  3. Efficient Rendering with Tile Local Storage
  • zel013
    zel013 over 4 years ago
    Can this extention render to multi target in the last pass ?
  • Join the Upscaling Revolution with Arm Accuracy Super Resolution (Arm ASR)
    Lisa Sheckleford
    Lisa Sheckleford
    With Arm ASR you can easily improve frames per second, enhance visual quality, and prevent thermal throttling for smoother, longer gameplay.
    • March 18, 2025
  • Generative AI in game development
    Roberto Lopez Mendez
    How is Generative AI (GenAI) technology impacting different areas of game development?
    • March 13, 2025
  • Physics simulation with graph neural networks targeting mobile
    Tomas Zilhao Borges
    Tomas Zilhao Borges
    In this blog post, we perform a study of the GNN architecture and the new TF-GNN API and determine whether GNNs are a viable approach for implementing physics simulations.
    • February 26, 2025
