Test requirements and code are similar across test items for SBSA (430) and BSA (830). Why did the test pass in SBSA but fail for us with the BSA equivalent?
  • Though the tests are the same,  the checks are made on different devices in each case
    SBSA tests are run only on RCiEP and  iEP/RP devices
    BSA is run for Root Port and End Point
    In the case where the the failure is in the BSA tests - this would suggest a failure in End Point devices.
