dma-330 validation simulation build error
Hi there,
I am studying the DMA-330 rtl testbench and trying to build the simulation according to "dma-330 command line out of box test flow". The manual is still using the VCS 2006 as an example. But the earliest version of VCS I can access is VCS 2016.
Now I get the following error of dependencies issue during the validation building. Is there a workaround? Thank you!
