We use IP-XACT based automation tools, mainly for register views, so need IP-XACT description of the APB registers for the CMSDK components.
Hi Moogyd,
The CMSDK components do not come with IP-XACT descriptions, either for RTL stitching purposes or register descriptions, so unfortunately you would need to create the required descriptions based on the details found in the "Programmers model" sections of each APB component in the CMSDK TRM.
Regards,
JD
Thanks JD,
