hello,I have confirmed the problem of using the sie-200 IP ahb synchronous bridge.
1.Whether the AHB5 to AHB5 sync-down bridge requires that the slave hready_m remain high after the handshake is set to high in the data phase,and cannot be pulled down before the next data access phase.
2.Whether the AHB5 to AHB5 synchronous bridge requires that the slave hready_m remain high after the handshake is set to high in the data phase,and cannot be pulled down before the next data access phase.
3.Whether the AHB5 to AHB5 synchronous bridge requires that the hready_m input of the slave is high when the slave is idle.
4.Whether the AHB5 to AHB5 low-latency sync-down bridge requires that the slave hready_m remain high after the handshake is set to high in the data phase,and cannot be pulled down before the next data access phase. 5.Whether the AHB5 to AHB5 low-latency sync-down bridge requires that the hready_m input of the slave is high when the slave is idle.
