When I am reading 'ARM' ® CoreLink SIE-200 System IP for Embedded "Technical Reference Manual.
Regarding the AHB5 exclusive access monitor, there is a paragraph that reads:
Can it be understood as ' hexokay_m signal is tied 0 'in the following figure?
Because during integration, the hexokay_m signal is the signal input from external devices to the AHB5 exclusive access monitor module. But my external device did not do any additional logic to generate hexokay_m signals.
If the AHB5 exclusive access monitor module of CoreLink SIE-200 System IP is used, Can the hexokay_m signal is tied 0 ?
