I set ARMLMD_LICENSE_FILE=/home/my/tool/setup_files/license.dat , built successfully , but when I run isim_system , it returns the errors below:
Starting process with command line: /home/my/tool/FastModels/FastModelsPortfolio_11.17/examples/LISA/FVP_VE/Build_Cortex-A9x4/Linux64-Release-GCC-7.3/isim_systemterminal_0: Listening for serial connection on port 5009terminal_1: Listening for serial connection on port 5010terminal_2: Listening for serial connection on port 5011terminal_3: Listening for serial connection on port 5012Error: license error: License checkout for feature FM_ARM_Public with version 11.17 has been denied by Flex back-end. Error code: -5No such feature exists.Feature: FM_ARM_PublicLicense path: /home/my/tool/setup_files/license.dat:/opt/arm/licenses/license.dat:FlexNet Licensing error:-5,357License checkout for feature SG_ARM_Cortex-A9MP_CT with version 11.17 has been denied by Flex back-end. Error code: -5No such feature exists.Feature: SG_ARM_Cortex-A9MP_CTLicense path: /home/my/tool/setup_files/license.dat:/opt/arm/licenses/license.dat:FlexNet Licensing error:-5,357In file: /tmp/plgbuild/abs_build/1146240_58962/trunk/work/fastsim/Framework/scx/SCXSimulationEngine.cpp:3241Info: /OSCI/SystemC: Simulation stopped by user.Information (Run Command) ----------------------------------------------------------------------------------------------Run Command process completed successfully.----------------------------------------------------------------------------------------------
my license info:
Anyone can tell me the reason why it failed ?
Thanks a lot
It looks like you are trying to run a Cortex-A9MP model with a Cortex-A9UP license. Send an email to license.support@arm.com and request a new eval license.
thanks a lot.
