What should be the behavior of an AHB5 slave when:
it is trust peripheral and receives a transaction with hnonsec=1it is trust peripheral and receives a transaction with hnonsec=0it is not trust peripheral and receives a transaction with hnonsec=1it is not trust peripheral and receives a transaction with hnonsec=0
Thank you very much in advance.
BR,Joaquin
This isn't quite the right way of thinking about this.
If the slave/subordinate does not trust the device issuing the transaction, then it would likely ignore the HNONSEC signal. In this case, this form of security in the system is broken as a device can issue secure transactions that is not trusted.
Instead, the system should be designed such that only trusted managers can issue transactions with HNONSEC = 0. The subordinate can then use HNONSEC to determine whether accesses can be made to a resource or memory location that the subordinate considers to be secure.
