AXI-lite tlast signal missing and tready behavioral
Dear Forum,
Can someone please clarify my 2 questions:
a)
Why in AXI lite protocol there is no tlast port?
Mainly AXI lite consists of AXI-stream protocols, but there is no tlast port in AXI lite. Can someone justify what was the reason of not including the tlast port in AXI-lite.
b)
Can AXI stream tready stay high after handhsake happens?
When tvalid is high and tready also goes high, that means handshake occurred and data transfered from master to slave. So after that handshake can tready still stay high, meaning that it can receive new data? Usually after all handshake events tready goes to low.
Hayk
  • a)
    You seem to be confusing AXI-Lite and AXI-Stream, which are two different protocols with different specifications.
    AXI-Lite does not have a WLAST or RLAST signal as all transactions are comprised of one transfer.  The LAST signal would constantly be high in AXI-Lite and so is not needed.
    AXI-Stream does have a TLAST signal, although it is optional.  See 3.1.3 in the AXI4-Steam specification for more details.
    Yes, TREADY can remain high after the transfer handshake has occurred if the interface can accept additional transfers immediately.
  • Thank you for the answer.
    Would you please explain little bit more what you mean by saying:all transactions are comprised of one transfer.
    I understand that each handshake of tvalid&trady is one transaction, but how it differ from the transfer
  • I think you're still confusing the signal naming a little - AXI-Stream uses signals named t* (e.g. tvalid, tkeep etc).  AXI-Lite uses standard AXI signal naming (e.g. awvalid, araddr, rdata etc.).
    In normal AXI, each valid/ready handshake is a single transfer.  So an AW ready/valid handshake, and then the W ready/valid handshake are two transfers.
    The address request, and all the associated data/responses to it are considered a single transaction.  In order words, a single transaction can be made up of many transfers.  For example, an AW, multiple Ws and the B response are all a single transaction.
    In the case of AXI-Lite every transaction only has a single data transfer.  Therefore, a AxLEN signal and an xLAST signal aren't required.
