Is anyone having issues on Android with creating an EGL view in native code, then having crashes on suspend/resume?
The problem seems to be in creating the EGL surface in Native code. We have a game that creates the EGL surface in Java that this is not happening on.
Anyone else having this issue?
EDIT:
I've attached a stack trace if that helps.
Mali01.txt.zip
