TP-LINK BIG EYE (TP MINI)
I'd like to change the current Android 4.2 OS to other Linux, because it doesn't work well, and the support is only in chinese language. So, difficult for me.
It seems, supports only PPPoE... I have Cable net...
The hardware:
CPU - ARM Cortex A9 dual core 1.6GHz
Chipset - RK3066
GPU - ARM quad core Mali-400 MP (3D: Shutter, polarizing)
RAM - 1GB DDR3
ROM - 4GB NAND Flash
External storage - USB flash drive max. 2TB or mini SD card up to 32GB
Network - Ethernet RJ45 + WiFi 802.11b/g/n
HDMI - V1.3,supports 480P, 720P, 1080P resolution
USB - two USB2.0 ports...
I'd like to use this TPLINK BIG EYE as a router (firewall, upnp)
as a DLNA server,
as a torrent client,
and skype client too.
Is it here someone who has the similar tool and problem?
Thank You
0
