Morello board hangs before reaching UEFI at LcdGraphicsOutputDxe.efi
I just started with the Morello board, and after flashing the latest prebuilt on a USB memory,  Linux wouldn't boot to home and hangs at SMP bringup which pointed me to
 Morello: Pre-built images stall at "smp: Bringing up secondary CPUs"
Then I go the latest firmware prebuilt
https://git.morello-project.org/morello/board-firmware/-/tree/morello/mainline?ref_type=heads
And flashed it on the SD card as mentioned in
https://git.morello-project.org/morello/docs/-/blob/morello/mainline/firmware/user-guide.rst#id23
And now I can't reach UEFI boot menu and it hangs as follows:
add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/HttpDxe/HttpD0
Loading driver at 0x000F7F30000 EntryPoint=0x000F7F315DC HttpDxe.efi
add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/HttpBootDxe/H0
Loading driver at 0x000F7F17000 EntryPoint=0x000F7F185DC HttpBootDxe.efi
ConvertPages: failed to find range 180000000 - 180022FFF
Loading driver at 0x000F7EF4000 EntryPoint=0x000F7EF6008
add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/Platform/ARM/Morello/Dri0
Loading driver at 0x000F7EED000 EntryPoint=0x000F7EEE2AC PlatformDxe.efi
[PlatformDxe:I2cEnableBusConf]: requested bus speed 400000 != configured bus speed 386363
add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/ArmPlatformPkg/Drivers/L0
Loading driver at 0x000F7EE3000 EntryPoint=0x000F7EE44C4 LcdGraphicsOutputDxe.efi
Please note that I have no screen connected, and when I connect one via HDMI it still hangs with slightly different error
EDID block read interrupt not set
InitializeDisplay: ERROR - Can not initialise the display. Exit Status=Time out
Thanks,
Mostafa
  • Hi Mostafa,
    Can you please confirm if you flashed the complete board-firmware or only the binaries in SOFTWARE folder? Also, can you share the complete MCC, SCP and AP logs? I can't reproduce the issue on my end (with the mainline board-firmware).
    Thanks,
    Himanshu
  • Hi Himanshu,
    I flashed the full firmware as instructed in the user-guide.rst
    $> sudo mount /dev/sdX1 /mnt
    $> sudo rm -rf /mnt/*
    $> sudo cp -r workspace/bsp/board-firmware/* /mnt/
    $> sudo umount /mnt
    I am using mainline prebuilt: commit 50e4c95 ("Merge branch 'morello/release-1.8' into 'morello/mainline'")
    MCC log:
    Cmd>
    Cmd>
    Cmd> reboot
    Rebooting...
    Disabling debug USB..
    MCC to access SD card request acknowledged.
    Clear ULINK JTAG
    Board rebooting...
    Powering up system...
    Clear ULINK JTAG
    Time :  03:02:15
    Date :  05:11:2024
    Programming Boot FLASH from \MB\HBI0364B\mbb_v233.ebf
    Device programmed: 0%Device programmed: 1%Device programmed: 3%Device programmed: 4%Device programmed: 6%Device programmed: 7%Device programmed: 9%Device programmed: 10%Device programmed: 12%Device programmed: 14%Device programmed: 15%Device programmed: 17%Device programmed: 18%Device programmed: 20%Device programmed: 21%Device programmed: 23%Device programmed: 24%Device programmed: 26%Device programmed: 28%Device programmed: 29%Device programmed: 31%Device programmed: 32%Device programmed: 34%Device programmed: 35%Device programmed: 37%Device programmed: 39%Device programmed: 40%Device programmed: 42%Device programmed: 43%Device programmed: 45%Device programmed: 46%Device programmed: 48%Device programmed: 49%
    Boot FLASH updated.
    Powering down...
    SPI Write command to PCC: register 3 cmd 0xD003 tx data 0x1
    SPI Return data from PCC: register 3 cmd 0x2000 rx data 0x0
    Resetting board.
    Clear ULINK JTAG
    Arm M1SDP MCC Boot loader v1.0.0
    HBI0364 build 641
    MBbios update in progress DO NOT SWITCH OFF...
    Device programmed: 1%Device programmed: 3%Device programmed: 4%Device programmed: 6%Device programmed: 7%Device programmed: 9%Device programmed: 10%Device programmed: 12%Device programmed: 14%Device programmed: 15%Device programmed: 17%Device programmed: 18%Device programmed: 20%Device programmed: 21%Device programmed: 23%Device programmed: 25%Device programmed: 26%Device programmed: 28%Device programmed: 29%Device programmed: 31%Device programmed: 32%Device programmed: 34%Device programmed: 35%Device programmed: 37%Device programmed: 39%Device programmed: 40%Device programmed: 42%Device programmed: 43%Device programmed: 45%Device programmed: 46%Device programmed: 48%Device programmed: 50%
    MBbios update complete.
    MCC: Power On
    Clear ULINK JTAG
    Time :  03:02:53
    Date :  05:11:2024
    Arm M1SDP MCC Firmware v2.3.3
    Build Date: Jun 23 2023
    Clear ULINK JTAG
    Time :  03:02:58
    Date :  05:11:2024
    Switching on ATXPSU...
    Switching on main power...
    12V Rail Check Pass
    Reading Board File \MB\HBI0364B\io_v010f.txt
    TOTAL OSCCLKS: 15
    PMIC RAM configuration (80_1_86G.bin)...
    Temperature (deg C)
    Outlet = 28.2 PMIC   = 33.9 SoC = 32.1 IN2  = 32.9 IN1 = 30.9
    MidBrd = 33   PCIeSW = 30   MCC = 29.1 FPGA = 35.0 SoC Fan Speed = 9%
    ALERT off
    Configuring motherboard (rev B, var A)...
    Configuring FPGA from file \MB\HBI0364B\io_v010f.bit
    Address: 0x00000000Address: 0x00020000Address: 0x00040000Address: 0x00060000Address: 0x00080000Address: 0x000A0000Address: 0x000C0000Address: 0x000E0000Address: 0x00100000Address: 0x00120000Address: 0x00140000Address: 0x00160000Address: 0x00180000Address: 0x001A0000Address: 0x001C0000Address: 0x001E0000Address: 0x00200000Address: 0x00220000Address: 0x00240000Address: 0x00260000Address: 0x00280000Address: 0x002A0000Address: 0x002C0000Address: 0x002E0000Address: 0x00300000Address: 0x00320000Address: 0x00340000Address: 0x00360000Address: 0x00380000Address: 0x003A0000Address: 0x003C0000Address: 0x003E0000Address: 0x00400000Address: 0x00420000Address: 0x00440000Address: 0x00460000Address: 0x00480000Address: 0x004A0000Address: 0x004C0000Address: 0x004E0000Address: 0x00500000Address: 0x00520000Address: 0x00540000Address: 0x00560000Address: 0x00580000Address: 0x005A0000Address: 0x005C0000Address: 0x005E0000Address: 0x00600000Address: 0x00620000Address: 0x00640000Address: 0x00660000Address: 0x00680000Address: 0x006A0000Address: 0x006C0000Address: 0x006E0000Address: 0x00700000Address: 0x00720000Address: 0x00740000Address: 0x00760000Address: 0x00780000Address: 0x007A0000Address: 0x007C0000Address: 0x007E0000
    FPGA configuration complete.
    Config clocks num: 15
    OSCCLK0  : 50.000000MHz
    OSCCLK1  : 50.000000MHz
    OSCCLK2  : 50.000000MHz
    OSCCLK3  : 50.000000MHz
    OSCCLK4  : 50.000000MHz
    OSCCLK5  : 50.000000MHz
    OSCCLK6  : 50.000000MHz
    OSCCLK7  : 50.000000MHz
    OSCCLK8  : 75.000000MHz
    OSCCLK9  : 85.000000MHz
    OSCCLK10  : 12.288000MHz
    OSCCLK11  : 50.000000MHz
    OSCCLK12  : 50.000000MHz
    OSCCLK13  : 50.000000MHz
    OSCCLK14  : 170.000000MHz
    OSCCLK setup: PASSED
    GTXCLK setup: PASSED
    EEPROM config found
    File to compare \MB\HBI0364B\pci_v002.bin \MB\HBI0364B\pci_v002.bin
    UPDATE IN PROGRESS
    PCIe PEX I2C configuration
    PCIe I2C R/W test passed...
    Reading PCIe EEPROM file \MB\HBI0364B\pci_v002.bin
    DMA TX Handler
    Address: 0x00000000Address: 0x00000001Address: 0x00000002Address: 0x00000003Address: 0x00000004Address: 0x00000005Address: 0x00000006Address: 0x00000007Address: 0x00000008Address: 0x00000009Address: 0x0000000AAddress: 0x0000000BAddress: 0x0000000CAddress: 0x0000000DAddress: 0x0000000EAddress: 0x0000000FAddress: 0x00000010Address: 0x00000011Address: 0x00000012Address: 0x00000013Address: 0x00000014Address: 0x00000015Address: 0x00000016Address: 0x00000017
    PCIe EEPROM programmed
    Writing SCC 0x014 with ACLK 50000000 Hz
    Writing SCC 0x00C with 0x00000003
    Writing SCC 0x020 with 0x11090805
    Writing SCC 0x024 with 0x06060606
    Writing SCC 0x028 with 0x00000606
    Writing SCC 0x1160 with 0x00000001
    Writing SCC 0x1164 with 0x01000000
    Writing SCC 0x1168 with 0x00000000
    Writing SCC 0x116C with 0x00000000
    Writing SCC 0x1180 with 0x00000000
    Writing SCC 0x1184 with 0x0000000C
    Writing SCC 0x1188 with 0x00000000
    Writing SCC 0x118C with 0x00000000
    Writing SCC 0x1190 with 0x00000000
    Writing SCC 0x1194 with 0x00000000
    Writing SCC 0x1198 with 0x00000000
    Writing SCC 0x119C with 0x00000000
    Reading SCC 0xFF8 with 0x0A364A08
    Reading SCC 0xFFC with 0x41050000
    QSPI Controller detected id = 0x4000303
    Device ID 0x20, 0xBB, 0x19
    Setting QSPI dummy clocks...
    Dummy clocks already set
    Updating SCP qspi with PCC bios
    File \MB\HBI0364B\pcc_v057.bin written to MCC memory address 0x65F00000
    DMA TX Handler
    PCC Bios updated from \MB\HBI0364B\pcc_v057.bin
    Waiting for PCC to copy boot loader from QSPI...
    Powering down...
    Resetting board.
    Clear ULINK JTAG
    HBI0364 build 641
    MCC: Power On
    Clear ULINK JTAG
    Time :  03:03:41
    Date :  05:11:2024
    Clear ULINK JTAG
    Time :  03:03:46
    Date :  05:11:2024
    12V Rail Check Pass
    TOTAL OSCCLKS: 15
    Temperature (deg C)
    Outlet = 27.9 PMIC   = 33.4 SoC = 30.9 IN2  = 31.9 IN1 = 30.3
    MidBrd = 33   PCIeSW = 33   MCC = 28.9 FPGA = 34.7 SoC Fan Speed = 9%
    ALERT off
    EEPROM config found
    Reading images file \MB\HBI0364B\images.txt
    Updating MCP file
    File \SOFTWARE\mcp_fw.bin written to MCC memory address 0x64000000
    DMA TX Handler
    Image: mcp_fw updated from \SOFTWARE\mcp_fw.bin
    Updating SCP file
    File \SOFTWARE\scp_fw.bin written to MCC memory address 0x64000000
    DMA TX Handler
    Image: scp_fw updated from \SOFTWARE\scp_fw.bin
    Updating AP QSPI file
    File \SOFTWARE\fip.bin written to MCC memory address 0x66000000
    DMA TX Handler
    Image: fip updated from \SOFTWARE\fip.bin
    PCIe NIC MAC address = 0002 F70094D0
    PCC MAC address = 0002 F70094CF
    LAN9221 was identified successfully.
    MAC addrs test: PASSED
    SMC MAC address 0002-F700-94D1
    Identifying DDR 0
    Device Information
    Manufacturer ID = 80 2C
    Module Part Number = 9ASF1G72PZ-2G9E1
    Module Serial Number = F2 67 E5 3E
    Identifying DDR 1
    Device Information
    Module Serial Number = F2 67 CF 48
    Setting System LEDs[7:4]
    Setting PCIe_nPERST/PCIESW_PERSTN
    PCIe control C2C disabled
    APUART0 connected to USBPORT_3
    SCPUART connected to USBPORT_4
    MCPUART connected to USBPORT_5
    PL031 Date & Time set = Tue Nov  5 03:04:44 2024
    QSPI test (0x6403FEF8):0x5144F641
    Releasing SOC_nPOR/SOC_nSRST
    Setting I2C_MUX to SCP
    USB Serial Number = 500540992008
    Cmd>
    SCP log:
    [    0.000000]  ___  ___ ___      __ _
    [    0.000000] / __|/ __| _ \___ / _(_)_ _ _ ____ __ ____ _ _ _ ___
    [    0.000000] \__ | (__|  _|___|  _| | '_| '  \ V  V / _` | '_/ -_)
    [    0.000000] |___/\___|_|     |_| |_|_| |_|_|_\_/\_/\__,_|_| \___|
    [    0.000000]
    [    0.000000] v2.7.0_2020-11-19_07-20-34-d49e1335
    [    0.000000]
    [    0.000000] [FWK] Module initialization complete!
    [    0.000000] [ROM] Trying to identify FIP at 0x30000000
    [    0.000000] [ROM] Located SCP_BL2:
    [    0.000000] [ROM]   address: 0x30000060
    [    0.000000] [ROM]   size   : 177052
    [    0.000000] [ROM]   flags  : 0x0000000000000000
    [    0.000000] [ROM] Copying SCP_BL2 to ITCRAM...!
    [    0.000000] [ROM] Done!
    [    0.000000] [ROM] Jumping to SCP_BL2
    [    0.000000]
    [    0.000000] 1.8_c0d655b
    [    0.000000]
    [    0.000000] [CMN_SKEENA] Multichip mode: no
    [    0.000000] [CMN_SKEENA] Chip ID: 0
    [    0.000000] [PVT] Morello Sensor Library version 2.0
    [    0.000000] [PVT] Started driver version 1.0
    [    0.000000] [MORELLO SYSTEM] Requesting SYSTOP initialization...
    [    0.000000] [CMN_SKEENA] Starting discovery...
    [    0.000000] [CMN_SKEENA] XP (4, 1) ID:264, LID:9
    [    0.000000] [CMN_SKEENA] XP (4, 0) ID:256, LID:4
    [    0.000000] [CMN_SKEENA] XP (3, 1) ID:200, LID:8
    [    0.000000] [CMN_SKEENA]   HN-F ID:200, LID:3 @0x71900000
    [    0.000000] [CMN_SKEENA] XP (3, 0) ID:192, LID:3
    [    0.000000] [CMN_SKEENA]   HN-F ID:196, LID:1 @0x71804000
    [    0.000000] [CMN_SKEENA]   Found external node ID: 192
    [    0.000000] [CMN_SKEENA] XP (2, 1) ID:136, LID:7
    [    0.000000] [CMN_SKEENA]   Found external node ID: 140
    [    0.000000] [CMN_SKEENA]   HN-F ID:136, LID:2 @0x71100000
    [    0.000000] [CMN_SKEENA] XP (2, 0) ID:128, LID:2
    [    0.000000] [CMN_SKEENA]   HN-F ID:132, LID:0 @0x71004000
    [    0.000000] [CMN_SKEENA]   SBSX ID:128, LID:0 @0x71000000
    [    0.000000] [CMN_SKEENA] XP (1, 1) ID:72, LID:6
    [    0.000000] [CMN_SKEENA]   Found CXLA at node ID: 78
    [    0.000000] [CMN_SKEENA]   RN-SAM ID:76, LID:0 @0x70954000
    [    0.000000] [CMN_SKEENA]   CXHA ID:76, LID:0 @0x70914000
    [    0.000000] [CMN_SKEENA]   CXRA ID:76, LID:0 @0x70904000
    [    0.000000] [CMN_SKEENA]   HN-I ID:72, LID:1 @0x70910000
    [    0.000000] [CMN_SKEENA] XP (1, 0) ID:64, LID:1
    [    0.000000] [CMN_SKEENA]   HN-I ID:68, LID:0 @0x70854000
    [    0.000000] [CMN_SKEENA]   DTC ID:68, LID:0 @0x70834000
    [    0.000000] [CMN_SKEENA]   DVM ID:68, LID:0 @0x70824000
    [    0.000000] [CMN_SKEENA]   RN-SAM ID:64, LID:0 @0x70820000
    [    0.000000] [CMN_SKEENA]   RN-D ID:64, LID:2 @0x70810000
    [    0.000000] [CMN_SKEENA] XP (0, 1) ID:8, LID:5
    [    0.000000] [CMN_SKEENA]   RN-SAM ID:12, LID:0 @0x70124000
    [    0.000000] [CMN_SKEENA]   RN-D ID:12, LID:4 @0x70114000
    [    0.000000] [CMN_SKEENA]   RN-SAM ID:8, LID:0 @0x70120000
    [    0.000000] [CMN_SKEENA]   RN-D ID:8, LID:3 @0x70110000
    [    0.000000] [CMN_SKEENA] XP (0, 0) ID:0, LID:0
    [    0.000000] [CMN_SKEENA]   RN-SAM ID:4, LID:0 @0x70024000
    [    0.000000] [CMN_SKEENA]   RN-D ID:4, LID:1 @0x70014000
    [    0.000000] [CMN_SKEENA]   RN-SAM ID:0, LID:0 @0x70020000
    [    0.000000] [CMN_SKEENA]   RN-D ID:0, LID:0 @0x70010000
    [    0.000000] [CMN_SKEENA] Total internal RN-SAM nodes: 6
    [    0.000000] [CMN_SKEENA] Total external RN-SAM nodes: 2
    [    0.000000] [CMN_SKEENA] Total HN-F nodes: 4
    [    0.000000] [CMN_SKEENA] Total RN-F nodes: 2
    [    0.000000] [CMN_SKEENA] Total RN-D nodes: 5
    [    0.000000] [CMN_SKEENA] Total RN-I nodes: 0
    [    0.000000] [CMN_SKEENA] CCIX CXLA node at: 0x70924000
    [    0.000000] [CMN_SKEENA] CCIX CXRA node at: 0x70904000
    [    0.000000] [CMN_SKEENA] CCIX CXHA node at: 0x70914000
    [    0.000000] [CMN_SKEENA] Configuring RN-SAM for node id 76 at 0x70954000
    [    0.000000] [CMN_SKEENA]   [0x0000000000000000 - 0x000007FFFFFFFFFF] System
    [    0.000000] [CMN_SKEENA]   [0x0000000000000000 - 0x0000000007FFFFFF] Sub-Sys
    [    0.000000] [CMN_SKEENA]   [0x0000000008000000 - 0x000000000FFFFFFF] I/O
    [    0.000000] [CMN_SKEENA]   [0x0000000010000000 - 0x000000001FFFFFFF] I/O
    [    0.000000] [CMN_SKEENA]   [0x0000000020000000 - 0x000000003FFFFFFF] I/O
    [    0.000000] [CMN_SKEENA]   [0x0000000040000000 - 0x000000005FFFFFFF] I/O
    [    0.000000] [CMN_SKEENA]   [0x0000000060000000 - 0x000000006FFFFFFF] I/O
    [    0.000000] [CMN_SKEENA]   [0x0000000070000000 - 0x000000007FFFFFFF] I/O
    [    0.000000] [CMN_SKEENA]   [0x0000000400000000 - 0x00000007FFFFFFFF] I/O
    [    0.000000] [CMN_SKEENA]   [0x0000000800000000 - 0x0000000FFFFFFFFF] I/O
    [    0.000000] [CMN_SKEENA]   [0x0000001000000000 - 0x0000001FFFFFFFFF] I/O
    [    0.000000] [CMN_SKEENA]   [0x0000002000000000 - 0x00000027FFFFFFFF] I/O
    [    0.000000] [CMN_SKEENA]   [0x0000002800000000 - 0x0000002FFFFFFFFF] I/O
    [    0.000000] [CMN_SKEENA]   [0x0000003000000000 - 0x0000003FFFFFFFFF] I/O
    [    0.000000] [CMN_SKEENA]   [0x0000004000000000 - 0x0000004FFFFFFFFF] I/O
    [    0.000000] [CMN_SKEENA]   [0x0000005000000000 - 0x0000005FFFFFFFFF] System
    [    0.000000] [CMN_SKEENA]   [0x0000006000000000 - 0x0000007FFFFFFFFF] System
    [    0.000000] [CMN_SKEENA]   [0x0000008000000000 - 0x000000807FFFFFFF] System
    [    0.000000] [CMN_SKEENA]   [0x0000040000000000 - 0x000007FFFFFFFFFF] CCIX
    [    0.000000] [CMN_SKEENA] Configuring RN-SAM for node id 64 at 0x70820000
    [    0.000000] [CMN_SKEENA] Configuring RN-SAM for node id 12 at 0x70124000
    [    0.000000] [CMN_SKEENA] Configuring RN-SAM for node id 8 at 0x70120000
    [    0.000000] [CMN_SKEENA] Configuring RN-SAM for node id 4 at 0x70024000
    [    0.000000] [CMN_SKEENA] Configuring RN-SAM for node id 0 at 0x70020000
    [    0.000000] [CMN_SKEENA] Done
    [    0.000000] [APContext] Zeroing AP context area [0xa4000fc0 - 0xa4001000]
    [    0.000000] [DDR] Starting DDR subsystem initialization at 1466 MHz
    [    0.000000] [DDR] Identifying connected DIMM cards...
    [    0.000000]     DIMM 0 information:
    [    0.000000]     Manufacturer ID = 0x80 0x2c
    [    0.000000]     Module part number = 9ASF1G72PZ-2G9E1    $$
    [    0.000000]     Module serial number = 0xf2 0x67 0xe5 0x3e
    [    0.000000]     Module manufacturing week 20 year 21
    [    0.000000]     DIMM 1 information:
    [    0.000000]     Module serial number = 0xf2 0x67 0xcf 0x48
    [    0.000000] [DDR] Initialising DMC-Bing at 0x4e000000
    [    0.000000] [DDR] Configuring interrupts for DMC0
    [    0.000000] [DDR] Writing functional settings
    [    0.000000] [DDR-PHY] Initializing PHY at 0x0x50604000 for 1466 MHz speed
    [    0.000000] [DDR] Sending direct DDR commands
    [    0.000000] [DDR] Training DDR memories...
    [    0.000000] [DDR] Write leveling rank 1...
    [    0.000000] [DDR] PASS
    [    0.000000] [DDR] Read gate training
    [    0.000000] [DDR] A side...
    [    0.000000] [DDR] Read eye training
    [    0.000000] [DDR] B side...
    [    0.000000] [DDR] MC initiated update...
    [    0.000000] [DDR-PHY] Post training PHY setting at 0x50604000
    [    0.000000] [DDR-PHY] Performing write eye training...
    [    0.000000] [DDR-PHY] PASS!
    [    0.000000] [DDR] Enable DIMM refresh...
    [    0.000000] [DDR] Setting DMC to READY mode
    [    0.000000] [DDR] DMC init done.
    [    0.000000] [DDR] Initialising DMC-Bing at 0x4e100000
    [    0.000000] [DDR] Configuring interrupts for DMC1
    [    0.000000] [DDR-PHY] Initializing PHY at 0x0x50614000 for 1466 MHz speed
    [    0.000000] [DDR-PHY] Post training PHY setting at 0x50614000
    [    0.000000] [DDR] Verifying PHY status for DMC 0...
    [    0.000000] [DDR] Done
    [    0.000000] [DDR] Verifying PHY status for DMC 1...
    [    0.000000] [PCIe] Powering ON controller...
    [    0.004050] [PCIe] Timeout!
    [    0.006834] [FWK] Process event ([NOT 17:0]: [ELM 17:0] -> [ELM 34:0]) (-7)
    [    0.013758] [CCIX] Powering ON controller...
    [    0.018023] [CCIX] Timeout!
    [    0.020809] [FWK] Process event ([NOT 17:0]: [ELM 17:0] -> [ELM 34:1]) (-7)
    [    0.027733] [MORELLO SYSTEM] Setting AP Reset Address to 0x0000000000000000
    [    0.034688] [MORELLO SYSTEM] Collecting Platform information...
    [    0.040580] [MORELLO SYSTEM] Total usable DDR size: 16384MB
    [    0.050644] [MORELLO SYSTEM] Collecting Firmware version information...
    [    0.054380] [MORELLO SYSTEM] Fetching PCC firmware version
    [    0.064354] [MORELLO SYSTEM] Fetching MCC firmware version
    [    0.071472] [MORELLO SYSTEM] Enabling CoreSight debug non-secure access
    [    0.075214] [MORELLO SYSTEM] Temp of CLUS0 = 30C, CLUS1 = 30C, SYS = 29C
    [    0.081891] [MORELLO SYSTEM] Booting primary core at 2600 MHz...
    [    0.087908] [CMN_SKEENA] Configuring RN-SAM for node id 192 at 0x71800000
    [    0.094651] [CMN_SKEENA]   [0x0000000000000000 - 0x000007FFFFFFFFFF] System
    [    0.101683] [CMN_SKEENA]   [0x0000000000000000 - 0x0000000007FFFFFF] Sub-Sys
    [    0.108712] [CMN_SKEENA]   [0x0000000008000000 - 0x000000000FFFFFFF] I/O
    [    0.115398] [CMN_SKEENA]   [0x0000000010000000 - 0x000000001FFFFFFF] I/O
    [    0.122082] [CMN_SKEENA]   [0x0000000020000000 - 0x000000003FFFFFFF] I/O
    [    0.128766] [CMN_SKEENA]   [0x0000000040000000 - 0x000000005FFFFFFF] I/O
    [    0.135449] [CMN_SKEENA]   [0x0000000060000000 - 0x000000006FFFFFFF] I/O
    [    0.142133] [CMN_SKEENA]   [0x0000000070000000 - 0x000000007FFFFFFF] I/O
    [    0.148816] [CMN_SKEENA]   [0x0000000400000000 - 0x00000007FFFFFFFF] I/O
    [    0.155500] [CMN_SKEENA]   [0x0000000800000000 - 0x0000000FFFFFFFFF] I/O
    [    0.162184] [CMN_SKEENA]   [0x0000001000000000 - 0x0000001FFFFFFFFF] I/O
    [    0.168867] [CMN_SKEENA]   [0x0000002000000000 - 0x00000027FFFFFFFF] I/O
    [    0.175551] [CMN_SKEENA]   [0x0000002800000000 - 0x0000002FFFFFFFFF] I/O
    [    0.182234] [CMN_SKEENA]   [0x0000003000000000 - 0x0000003FFFFFFFFF] I/O
    [    0.188918] [CMN_SKEENA]   [0x0000004000000000 - 0x0000004FFFFFFFFF] I/O
    [    0.195602] [CMN_SKEENA]   [0x0000005000000000 - 0x0000005FFFFFFFFF] System
    [    0.202633] [CMN_SKEENA]   [0x0000006000000000 - 0x0000007FFFFFFFFF] System
    [    0.209664] [CMN_SKEENA]   [0x0000008000000000 - 0x000000807FFFFFFF] System
    [    0.216695] [CMN_SKEENA]   [0x0000040000000000 - 0x000007FFFFFFFFFF] CCIX
    AP log:
    NOTICE:  Booting Trusted Firmware
    NOTICE:  BL1: v2.4(debug):37a5f702b
    NOTICE:  BL1: Built : 14:51:05, Jan 27 2021
    INFO:    BL1: RAM 0x4074000 - 0x407f000
    INFO:    Using crypto library 'mbed TLS'
    INFO:    Loading image id=6 at address 0x4001010
    INFO:    Image id=6 loaded: 0x4001010 - 0x40014ce
    INFO:    Loading image id=31 at address 0x4001010
    INFO:    Image id=31 loaded: 0x4001010 - 0x400119c
    INFO:    FCONF: Config file with image ID:31 loaded at address = 0x4001010
    INFO:    Loading image id=24 at address 0x4001300
    INFO:    Image id=24 loaded: 0x4001300 - 0x40013e8
    INFO:    FCONF: Config file with image ID:24 loaded at address = 0x4001300
    INFO:    BL1: Loading BL2
    INFO:    Loading image id=1 at address 0x4057000
    INFO:    Image id=1 loaded: 0x4057000 - 0x406b961
    NOTICE:  BL1: Booting BL2
    INFO:    Entry point address = 0x4057000
    INFO:    SPSR = 0x3c5
    INFO:    FCONF: Reading FW_CONFIG firmware configuration file from: 0x4001010
    INFO:    FCONF: Reading firmware configuration information for: dyn_cfg
    INFO:    FCONF: Reading TB_FW firmware configuration file from: 0x4001300
    INFO:    FCONF: Reading firmware configuration information for: tbbr
    NOTICE:  BL2: 1.8_02f8715
    NOTICE:  BL2: Built : 12:02:04, Mar  6 2024
    WARNING: FCONF: Invalid config id 25
    INFO:    BL2: Doing platform setup
    INFO:    SDS: Detected SDS Memory Region (3520 bytes)
    INFO:    Total DIMM size: 16GB
    INFO:    Zeroing DDR memory range 0x80000000 - 0xFFFFFFFF
    INFO:    Zeroing DDR memory range 0x8080000000 - 0x8400000000
    INFO:    Configuring DMC Bing in server mode
    INFO:    Enabling ECC on DMCs
    INFO:    BL2: Loading image id 3
    INFO:    Loading image id=7 at address 0xff000000
    INFO:    Image id=7 loaded: 0xff000000 - 0xff000616
    INFO:    Loading image id=9 at address 0xff000000
    INFO:    Image id=9 loaded: 0xff000000 - 0xff0004e2
    INFO:    Loading image id=13 at address 0xff000000
    INFO:    Image id=13 loaded: 0xff000000 - 0xff000438
    INFO:    Loading image id=3 at address 0xff000000
    INFO:    Image id=3 loaded: 0xff000000 - 0xff00c164
    INFO:    BL2: Loading image id 23
    INFO:    Loading image id=6 at address 0xfeff8000
    INFO:    Image id=6 loaded: 0xfeff8000 - 0xfeff84be
    INFO:    Loading image id=23 at address 0xfeff8000
    INFO:    Image id=23 loaded: 0xfeff8000 - 0xfeffbe3c
    INFO:    BL2: Skip loading image id 25
    INFO:    BL2: Loading image id 5
    INFO:    Loading image id=11 at address 0xe0000000
    INFO:    Image id=11 loaded: 0xe0000000 - 0xe00004f2
    INFO:    Loading image id=15 at address 0xe0000000
    INFO:    Image id=15 loaded: 0xe0000000 - 0xe0000448
    INFO:    Loading image id=5 at address 0xe0000000
    INFO:    Image id=5 loaded: 0xe0000000 - 0xe0200000
    INFO:    BL2: Loading image id 27
    INFO:    Loading image id=27 at address 0xfef00000
    INFO:    Image id=27 loaded: 0xfef00000 - 0xfef001f0
    NOTICE:  BL1: Booting BL31
    INFO:    Entry point address = 0xff000000
    INFO:    SPSR = 0x3cd
    NOTICE:  BL31: 1.8_02f8715
    NOTICE:  BL31: Built : 12:02:04, Mar  6 2024
    INFO:    GICv3 without legacy support detected.
    INFO:    ARM GICv3 driver initialized in EL3
    INFO:    Maximum SPI INTID supported: 991
    INFO:    Initializing SCMI driver on channel 0
    INFO:    SCMI driver initialized
    INFO:    BL31: Initializing runtime services
    INFO:    BL31: rainier: CPU workaround for erratum 1868343 was applied
    INFO:    BL31: Preparing for EL3 exit to normal world
    INFO:    Entry point address = 0xe0000000
    INFO:    SPSR = 0x3c9
    UEFI firmware (version 1.8_3bf9a27:1.8_dc71a37 built at 12:02:29 on Mar  6 2024)
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/ArmPlatformPkg/PrePeiCore/PrePeiCoreUniCore/DEBUG/ArmPlatformPrePeiCore.dll 0xE000F800
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Core/Pei/PeiMain/DEBUG/PeiCore.dll 0xE0020240
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/PCD/Pei/Pcd/DEBUG/PcdPeim.dll 0xE0034240
    Loading PEIM at 0x000E0034160 EntryPoint=0x000E0034298 PcdPeim.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/Platform/ARM/Morello/Drivers/MorelloNtFwConfigPei/Soc/DEBUG/MorelloSocNtFwConfigPei.dll 0xE0042240
    Loading PEIM at 0x000E0042160 EntryPoint=0x000E0042290 MorelloSocNtFwConfigPei.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/ArmPlatformPkg/MemoryInitPei/MemoryInitPeim/DEBUG/MemoryInit.dll 0xE0005400
    Loading PEIM at 0x000E0005160 EntryPoint=0x000E0005A50 MemoryInit.efi
    Memory Init PEIM Loaded
     Memory Map
    Description                     :        START       -        END         [        SIZE        ] {              ATTR             }
    Generic Watchdog                : 0x000000002A440000 - 0x000000002A45FFFF [ 0x0000000000020000 ] { WRITE_THROUGH                 }
    REFCLK CNTRead                  : 0x000000002A800000 - 0x000000002A80FFFF [ 0x0000000000010000 ] { WRITE_THROUGH                 }
    AP_REFCLK CNTCL                 : 0x000000002A810000 - 0x000000002A81FFFF [ 0x0000000000010000 ] { WRITE_THROUGH                 }
    AP_REFCLK_NS CNTCTL             : 0x000000002A830000 - 0x000000002A83FFFF [ 0x0000000000010000 ] { WRITE_THROUGH                 }
    GIC-600                         : 0x0000000030000000 - 0x000000003003FFFF [ 0x0000000000040000 ] { WRITE_THROUGH                 }
    GICITS-600                      : 0x0000000030040000 - 0x00000000300BFFFF [ 0x0000000000080000 ] { WRITE_THROUGH                 }
    GICR-600                        : 0x00000000300C0000 - 0x00000000301BFFFF [ 0x0000000000100000 ] { WRITE_THROUGH                 }
    SMMU                            : 0x000000004F000000 - 0x000000004FFFFFFF [ 0x0000000001000000 ] { WRITE_THROUGH                 }
    non-secure SRAM                 : 0x0000000006000000 - 0x000000000600FFFF [ 0x0000000000010000 ] { UNCACHED_UNBUFFERED           }
    UART0                           : 0x000000002A400000 - 0x000000002A40FFFF [ 0x0000000000010000 ] { WRITE_THROUGH                 }
    Mali D-32                       : 0x000000002CC00000 - 0x000000002CEFFFFF [ 0x0000000000300000 ] { WRITE_THROUGH                 }
    DDR Primary                     : 0x0000000080000000 - 0x00000000FDFFFFFF [ 0x000000007E000000 ] { NONSECURE_UNCACHED_UNBUFFERED }
    DDR GOP carve out               : 0x00000000FE000000 - 0x00000000FEFFFFFF [ 0x0000000001000000 ] { UNCACHED_UNBUFFERED           }
    DDR Secondary                   : 0x0000008080000000 - 0x00000083FFFFFFFF [ 0x0000000380000000 ] { NONSECURE_UNCACHED_UNBUFFERED }
    AP QSPI flash device            : 0x000000001A000000 - 0x000000001BFFFFFF [ 0x0000000002000000 ] { WRITE_THROUGH                 }
    Expansion Peripherals           : 0x000000001C000000 - 0x000000001D2FFFFF [ 0x0000000001300000 ] { WRITE_THROUGH                 }
    PCIe ECAM Region                : 0x00000028C0000000 - 0x00000028CFFFFFFF [ 0x0000000010000000 ] { WRITE_THROUGH                 }
    PCIe MMIO32 & IO Region         : 0x0000000060000000 - 0x000000006F3FFFFF [ 0x000000000F400000 ] { WRITE_THROUGH                 }
    PCIe MMIO64 Region              : 0x0000000900000000 - 0x00000028BFFFFFFF [ 0x0000001FC0000000 ] { WRITE_THROUGH                 }
    CCIX ECAM Region                : 0x0000004FC0000000 - 0x0000004FCFFFFFFF [ 0x0000000010000000 ] { WRITE_THROUGH                 }
    CCIX MMIO32 & IO Region         : 0x0000000070000000 - 0x000000007F3FFFFF [ 0x000000000F400000 ] { WRITE_THROUGH                 }
    CCIX MMIO64 Region              : 0x0000003000000000 - 0x0000004FBFFFFFFF [ 0x0000001FC0000000 ] { WRITE_THROUGH                 }
    Virtual Memory Table setup complete.
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Core/Pei/PeiMain/DEBUG/PeiCore.dll 0xFDFDD240
    Loading PEIM at 0x000FDFDD160 EntryPoint=0x000FDFDD2E0 PeiCore.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/PCD/Pei/Pcd/DEBUG/PcdPeim.dll 0xFDFD5240
    Loading PEIM at 0x000FDFD5160 EntryPoint=0x000FDFD5298 PcdPeim.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/ArmPlatformPkg/PlatformPei/PlatformPeim/DEBUG/PlatformPei.dll 0xFDFD2240
    Loading PEIM at 0x000FDFD2160 EntryPoint=0x000FDFD2290 PlatformPei.efi
    Platform PEIM Loaded
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Core/DxeIplPeim/DxeIpl/DEBUG/DxeIpl.dll 0xFDFC8240
    Loading PEIM at 0x000FDFC8160 EntryPoint=0x000FDFC8298 DxeIpl.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/Platform/ARM/Morello/Drivers/MorelloHwConfigPei/MorelloHwConfigPei/DEBUG/MorelloHwConfigPei.dll 0xFD7AB240
    Loading PEIM at 0x000FD7AB160 EntryPoint=0x000FD7AB290 MorelloHwConfigPei.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/ArmPkg/Drivers/CpuPei/CpuPei/DEBUG/CpuPei.dll 0xFD7A2400
    Loading PEIM at 0x000FD7A2160 EntryPoint=0x000FD7A2800 CpuPei.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Core/Dxe/DxeMain/DEBUG/DxeCore.dll 0xFD751000
    Loading PEIM at 0x000FD750000 EntryPoint=0x000FD752808 DxeCore.efi
    Loading DXE CORE at 0x000FD750000 EntryPoint=0x000FD752808
    ReplaceTableEntry: splitting block entry with MMU disabled
    HOBLIST address in DXE = 0xFD4EC018
    Memory Allocation 0x00000004 0xE0000000 - 0xE01FFFFF
    Memory Allocation 0x00000004 0xFDFFF000 - 0xFDFFFFFF
    Memory Allocation 0x00000004 0xFDFFE000 - 0xFDFFEFFF
    Memory Allocation 0x00000004 0xFDFFD000 - 0xFDFFDFFF
    Memory Allocation 0x00000004 0xFDFFC000 - 0xFDFFCFFF
    Memory Allocation 0x00000004 0xFDFFB000 - 0xFDFFBFFF
    Memory Allocation 0x00000004 0xFDFFA000 - 0xFDFFAFFF
    Memory Allocation 0x00000004 0xFDFF9000 - 0xFDFF9FFF
    Memory Allocation 0x00000004 0xFDFF8000 - 0xFDFF8FFF
    Memory Allocation 0x00000004 0xFDFF7000 - 0xFDFF7FFF
    Memory Allocation 0x00000004 0xFDFF6000 - 0xFDFF6FFF
    Memory Allocation 0x00000004 0xFDFF5000 - 0xFDFF5FFF
    Memory Allocation 0x00000004 0xFDFF4000 - 0xFDFF4FFF
    Memory Allocation 0x00000004 0xFDFF3000 - 0xFDFF3FFF
    Memory Allocation 0x00000004 0xFDFF2000 - 0xFDFF2FFF
    Memory Allocation 0x00000004 0xFDFF1000 - 0xFDFF1FFF
    Memory Allocation 0x00000004 0xFD730000 - 0xFD74FFFF
    Memory Allocation 0x00000003 0xFDFDD000 - 0xFDFF0FFF
    Memory Allocation 0x00000003 0xFDFD5000 - 0xFDFDCFFF
    Memory Allocation 0x00000003 0xFDFD2000 - 0xFDFD4FFF
    Memory Allocation 0x00000003 0xFDFC8000 - 0xFDFD1FFF
    Memory Allocation 0x00000004 0xFDFB8000 - 0xFDFC7FFF
    Memory Allocation 0x00000004 0xFD7AF000 - 0xFDFB7FFF
    Memory Allocation 0x00000003 0xFD7AB000 - 0xFD7AEFFF
    Memory Allocation 0x00000004 0xFD7A7000 - 0xFD7AAFFF
    Memory Allocation 0x00000003 0xFD7A2000 - 0xFD7A6FFF
    Memory Allocation 0x00000003 0xFD750000 - 0xFD7A1FFF
    Memory Allocation 0x00000004 0xFD72F000 - 0xFD72FFFF
    Memory Allocation 0x00000004 0xF6000000 - 0xF601FFFF
    FV Hob            0xE0000000 - 0xE01FFFFF
    FV Hob            0xFD7B0000 - 0xFDFB797F
    FV2 Hob           0xFD7B0000 - 0xFDFB797F
                      00000000-0000-0000-0000-000000000000 - 9E21FD93-9C72-4C15-8C4B-E77F1DB2D792
    FV3 Hob           0xFD7B0000 - 0xFDFB797F - 0x0 - 0x1
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/PCD/Dxe/Pcd/DEBUG/PcdDxe.dll 0xFD675000
    Loading driver at 0x000FD674000 EntryPoint=0x000FD6754CC PcdDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Core/RuntimeDxe/RuntimeDxe/DEBUG/RuntimeDxe.dll 0xF8670000
    Loading driver at 0x000F8660000 EntryPoint=0x000F86700B4 RuntimeDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/Metronome/Metronome/DEBUG/Metronome.dll 0xFD66F000
    Loading driver at 0x000FD66E000 EntryPoint=0x000FD66F0A4 Metronome.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/ResetSystemRuntimeDxe/ResetSystemRuntimeDxe/DEBUG/ResetSystemRuntimeDxe.dll 0xF85D0000
    Loading driver at 0x000F85C0000 EntryPoint=0x000F85D00B8 ResetSystemRuntimeDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/SecurityStubDxe/SecurityStubDxe/DEBUG/SecurityStubDxe.dll 0xFD663000
    Loading driver at 0x000FD662000 EntryPoint=0x000FD6635DC SecurityStubDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/Acpi/AcpiTableDxe/AcpiTableDxe/DEBUG/AcpiTableDxe.dll 0xFD656000
    Loading driver at 0x000FD655000 EntryPoint=0x000FD6565DC AcpiTableDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/HiiDatabaseDxe/HiiDatabaseDxe/DEBUG/HiiDatabase.dll 0xFD631000
    Loading driver at 0x000FD630000 EntryPoint=0x000FD6315DC HiiDatabase.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/Platform/ARM/Morello/ConfigurationManager/ConfigurationManagerDxe/ConfigurationManagerDxeSoc/DEBUG/ConfigurationManagerDxe.dll 0xFD629000
    Loading driver at 0x000FD628000 EntryPoint=0x000FD62908C ConfigurationManagerDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/DynamicTablesPkg/Drivers/DynamicTableFactoryDxe/DynamicTableFactoryDxe/DEBUG/DynamicTableFactoryDxe.dll 0xFD5EF000
    Loading driver at 0x000FD5EE000 EntryPoint=0x000FD5F348C DynamicTableFactoryDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/SerialDxe/SerialDxe/DEBUG/SerialDxe.dll 0xFD5E8000
    Loading driver at 0x000FD5E7000 EntryPoint=0x000FD5E808C SerialDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/ArmPkg/Drivers/ArmGic/ArmGicDxe/DEBUG/ArmGicDxe.dll 0xFD5E0000
    Loading driver at 0x000FD5DF000 EntryPoint=0x000FD5E0338 ArmGicDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/EmbeddedPkg/Drivers/FdtClientDxe/FdtClientDxe/DEBUG/FdtClientDxe.dll 0xFD5D7000
    Loading driver at 0x000FD5D6000 EntryPoint=0x000FD5D76B4 FdtClientDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/DevicePathDxe/DevicePathDxe/DEBUG/DevicePathDxe.dll 0xFD5C3000
    Loading driver at 0x000FD5C2000 EntryPoint=0x000FD5C34CC DevicePathDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/ArmPkg/Drivers/ArmPciCpuIo2Dxe/ArmPciCpuIo2Dxe/DEBUG/ArmPciCpuIo2Dxe.dll 0xFD5BC000
    Loading driver at 0x000FD5BB000 EntryPoint=0x000FD5BC08C ArmPciCpuIo2Dxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/DpcDxe/DpcDxe/DEBUG/DpcDxe.dll 0xFD5B5000
    Loading driver at 0x000FD5B4000 EntryPoint=0x000FD5B508C DpcDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/HttpUtilitiesDxe/HttpUtilitiesDxe/DEBUG/HttpUtilitiesDxe.dll 0xFD5AD000
    Loading driver at 0x000FD5AC000 EntryPoint=0x000FD5AD4AC HttpUtilitiesDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/SmbiosDxe/SmbiosDxe/DEBUG/SmbiosDxe.dll 0xFD5A3000
    Loading driver at 0x000FD5A2000 EntryPoint=0x000FD5A35DC SmbiosDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/ArmPkg/Drivers/CpuDxe/CpuDxe/DEBUG/ArmCpuDxe.dll 0xFD595000
    Loading driver at 0x000FD594000 EntryPoint=0x000FD59604C ArmCpuDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/FaultTolerantWriteDxe/FaultTolerantWriteDxe/DEBUG/FaultTolerantWriteDxe.dll 0xFD58A000
    Loading driver at 0x000FD589000 EntryPoint=0x000FD58A5DC FaultTolerantWriteDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/Platform/ARM/Morello/Drivers/LogoDxe/LogoDxe/DEBUG/LogoDxe.dll 0xFD566000
    Loading driver at 0x000FD565000 EntryPoint=0x000FD56608C LogoDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/DynamicTablesPkg/Drivers/DynamicTableManagerDxe/DynamicTableManagerDxe/DEBUG/DynamicTableManagerDxe.dll 0xFD55E000
    Loading driver at 0x000FD55D000 EntryPoint=0x000FD55E08C DynamicTableManagerDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/ArmPkg/Drivers/GenericWatchdogDxe/GenericWatchdogDxe/DEBUG/GenericWatchdogDxe.dll 0xFD557000
    Loading driver at 0x000FD556000 EntryPoint=0x000FD55709C GenericWatchdogDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/ArmPkg/Drivers/TimerDxe/TimerDxe/DEBUG/ArmTimerDxe.dll 0xFD550000
    Loading driver at 0x000FD54F000 EntryPoint=0x000FD5500CC ArmTimerDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/SetupBrowserDxe/SetupBrowserDxe/DEBUG/SetupBrowser.dll 0xFD52E000
    Loading driver at 0x000FD52D000 EntryPoint=0x000FD52E5DC SetupBrowser.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/BdsDxe/BdsDxe/DEBUG/BdsDxe.dll 0xFD50E000
    Loading driver at 0x000FD50D000 EntryPoint=0x000FD50E5DC BdsDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/ShellPkg/DynamicCommand/HttpDynamicCommand/HttpDynamicCommand/DEBUG/httpDynamicCommand.dll 0xFD4FA000
    Loading driver at 0x000FD4F9000 EntryPoint=0x000FD4FA4CC httpDynamicCommand.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/ShellPkg/DynamicCommand/TftpDynamicCommand/TftpDynamicCommand/DEBUG/tftpDynamicCommand.dll 0xF8550000
    Loading driver at 0x000F854F000 EntryPoint=0x000F85504CC tftpDynamicCommand.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/Platform/ARM/Morello/Drivers/SmbiosPlatformDxe/SmbiosPlatformDxe/DEBUG/SmbiosPlatformDxe.dll 0xFD4F1000
    Loading driver at 0x000FD4F0000 EntryPoint=0x000FD4F1500 SmbiosPlatformDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/Platform/ARM/Morello/Drivers/CadenceQspiDxe/CadenceQspiDxe/DEBUG/CadenceQspiDxe.dll 0xF8500000
    Loading driver at 0x000F84F0000 EntryPoint=0x000F85000C4 CadenceQspiDxe.efi
    Detected n25q256a SPI NOR flash with page size 256 B, erase size 4 KB, total 32 MB
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/Disk/RamDiskDxe/RamDiskDxe/DEBUG/RamDiskDxe.dll 0xF8490000
    Loading driver at 0x000F848F000 EntryPoint=0x000F84905DC RamDiskDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/DisplayEngineDxe/DisplayEngineDxe/DEBUG/DisplayEngine.dll 0xF8473000
    Loading driver at 0x000F8472000 EntryPoint=0x000F84735DC DisplayEngine.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Bus/Pci/PciHostBridgeDxe/PciHostBridgeDxe/DEBUG/PciHostBridgeDxe.dll 0xF8461000
    Loading driver at 0x000F8460000 EntryPoint=0x000F84614E4 PciHostBridgeDxe.efi
    RootBridge: PcieRoot(0x0)
      Support/Attr: 0 / 0
        DmaAbove4G: Yes
    NoExtConfSpace: No
         AllocAttr: 3 (CombineMemPMem Mem64Decode)
               Bus: 0 - FF Translation=0
                Io: 0 - 3FFFFF Translation=0
               Mem: 60000000 - 6EFFFFFF Translation=0
        MemAbove4G: 900000000 - 28BFFFFFFF Translation=0
              PMem: FFFFFFFFFFFFFFFF - 0 Translation=0
       PMemAbove4G: FFFFFFFFFFFFFFFF - 0 Translation=0
    RootBridge: Acpi(PNP0A09,0x0)
      Support/Attr: 0 / 0
        DmaAbove4G: Yes
    NoExtConfSpace: No
               Mem: 70000000 - 7EFFFFFF Translation=0
        MemAbove4G: 3000000000 - 4FBFFFFFFF Translation=0
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/Variable/RuntimeDxe/VariableRuntimeDxe/DEBUG/VariableRuntimeDxe.dll 0xF8410000
    Loading driver at 0x000F8400000 EntryPoint=0x000F8410150 VariableRuntimeDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/EmbeddedPkg/RealTimeClockRuntimeDxe/RealTimeClockRuntimeDxe/DEBUG/RealTimeClock.dll 0xF8320000
    Loading driver at 0x000F8310000 EntryPoint=0x000F832008C RealTimeClock.efi
    InitializeRealTimeClock: using default timezone/daylight settings
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/CapsuleRuntimeDxe/CapsuleRuntimeDxe/DEBUG/CapsuleRuntimeDxe.dll 0xF8280000
    Loading driver at 0x000F8270000 EntryPoint=0x000F82800A4 CapsuleRuntimeDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/MonotonicCounterRuntimeDxe/MonotonicCounterRuntimeDxe/DEBUG/MonotonicCounterRuntimeDxe.dll 0xF81E0000
    Loading driver at 0x000F81D0000 EntryPoint=0x000F81E008C MonotonicCounterRuntimeDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/Platform/ARM/Morello/Drivers/CadenceI2cDxe/CadenceI2cDxe/DEBUG/CadenceI2cDxe.dll 0xF86B5000
    Loading driver at 0x000F86B4000 EntryPoint=0x000F86B54C4 CadenceI2cDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/Platform/ARM/Morello/Drivers/Tda19988Dxe/Tda19988Dxe/DEBUG/Tda19988Dxe.dll 0xF8547000
    Loading driver at 0x000F8546000 EntryPoint=0x000F85474CC Tda19988Dxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/Console/ConPlatformDxe/ConPlatformDxe/DEBUG/ConPlatformDxe.dll 0xF8178000
    Loading driver at 0x000F8177000 EntryPoint=0x000F81783DC ConPlatformDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/Console/ConSplitterDxe/ConSplitterDxe/DEBUG/ConSplitterDxe.dll 0xF816A000
    Loading driver at 0x000F8169000 EntryPoint=0x000F816A4AC ConSplitterDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/Console/GraphicsConsoleDxe/GraphicsConsoleDxe/DEBUG/GraphicsConsoleDxe.dll 0xF815F000
    Loading driver at 0x000F815E000 EntryPoint=0x000F815F4AC GraphicsConsoleDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/Console/TerminalDxe/TerminalDxe/DEBUG/TerminalDxe.dll 0xF8151000
    Loading driver at 0x000F8150000 EntryPoint=0x000F81515DC TerminalDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/Platform/ARM/Drivers/BootMonFs/BootMonFs/DEBUG/BootMonFs.dll 0xF8145000
    Loading driver at 0x000F8144000 EntryPoint=0x000F81455DC BootMonFs.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/FatPkg/EnhancedFatDxe/Fat/DEBUG/Fat.dll 0xF8135000
    Loading driver at 0x000F8134000 EntryPoint=0x000F81355DC Fat.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/Disk/DiskIoDxe/DiskIoDxe/DEBUG/DiskIoDxe.dll 0xF812B000
    Loading driver at 0x000F812A000 EntryPoint=0x000F812B4AC DiskIoDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/Disk/PartitionDxe/PartitionDxe/DEBUG/PartitionDxe.dll 0xF811F000
    Loading driver at 0x000F811E000 EntryPoint=0x000F811F5DC PartitionDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/Disk/UnicodeCollation/EnglishDxe/EnglishDxe/DEBUG/EnglishDxe.dll 0xF8541000
    Loading driver at 0x000F8540000 EntryPoint=0x000F854108C EnglishDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Universal/FvSimpleFileSystemDxe/FvSimpleFileSystemDxe/DEBUG/FvSimpleFileSystem.dll 0xF8114000
    Loading driver at 0x000F8113000 EntryPoint=0x000F81144CC FvSimpleFileSystem.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Bus/I2c/I2cDxe/I2cDxe/DEBUG/I2cDxe.dll 0xF810A000
    Loading driver at 0x000F8109000 EntryPoint=0x000F810A5DC I2cDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Bus/Pci/PciBusDxe/PciBusDxe/DEBUG/PciBusDxe.dll 0xF80EF000
    Loading driver at 0x000F80EE000 EntryPoint=0x000F80EF5DC PciBusDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Bus/Ata/AtaAtapiPassThru/AtaAtapiPassThru/DEBUG/AtaAtapiPassThruDxe.dll 0xF80DC000
    Loading driver at 0x000F80DB000 EntryPoint=0x000F80DC5B4 AtaAtapiPassThruDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Bus/Ata/AtaBusDxe/AtaBusDxe/DEBUG/AtaBusDxe.dll 0xF80D0000
    Loading driver at 0x000F80CF000 EntryPoint=0x000F80D04C4 AtaBusDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Bus/Pci/SataControllerDxe/SataControllerDxe/DEBUG/SataController.dll 0xF80C8000
    Loading driver at 0x000F80C7000 EntryPoint=0x000F80C84AC SataController.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Bus/Pci/UhciDxe/UhciDxe/DEBUG/UhciDxe.dll 0xF80BB000
    Loading driver at 0x000F80BA000 EntryPoint=0x000F80BB4AC UhciDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Bus/Pci/EhciDxe/EhciDxe/DEBUG/EhciDxe.dll 0xF80AC000
    Loading driver at 0x000F80AB000 EntryPoint=0x000F80AC4AC EhciDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Bus/Pci/XhciDxe/XhciDxe/DEBUG/XhciDxe.dll 0xF8098000
    Loading driver at 0x000F8097000 EntryPoint=0x000F80984AC XhciDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Bus/Usb/UsbBusDxe/UsbBusDxe/DEBUG/UsbBusDxe.dll 0xF8088000
    Loading driver at 0x000F8087000 EntryPoint=0x000F808859C UsbBusDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Bus/Usb/UsbKbDxe/UsbKbDxe/DEBUG/UsbKbDxe.dll 0xF807C000
    Loading driver at 0x000F807B000 EntryPoint=0x000F807C4AC UsbKbDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Bus/Usb/UsbMassStorageDxe/UsbMassStorageDxe/DEBUG/UsbMassStorageDxe.dll 0xF8070000
    Loading driver at 0x000F806F000 EntryPoint=0x000F80704AC UsbMassStorageDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/MdeModulePkg/Bus/Pci/NvmExpressDxe/NvmExpressDxe/DEBUG/NvmExpressDxe.dll 0xF8060000
    Loading driver at 0x000F805F000 EntryPoint=0x000F80604AC NvmExpressDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/SnpDxe/SnpDxe/DEBUG/SnpDxe.dll 0xF8054000
    Loading driver at 0x000F8053000 EntryPoint=0x000F805459C SnpDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/VlanConfigDxe/VlanConfigDxe/DEBUG/VlanConfigDxe.dll 0xF8048000
    Loading driver at 0x000F8047000 EntryPoint=0x000F80485DC VlanConfigDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/MnpDxe/MnpDxe/DEBUG/MnpDxe.dll 0xF8037000
    Loading driver at 0x000F8036000 EntryPoint=0x000F803759C MnpDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/ArpDxe/ArpDxe/DEBUG/ArpDxe.dll 0xF802B000
    Loading driver at 0x000F802A000 EntryPoint=0x000F802B59C ArpDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/Dhcp4Dxe/Dhcp4Dxe/DEBUG/Dhcp4Dxe.dll 0xF801B000
    Loading driver at 0x000F801A000 EntryPoint=0x000F801B59C Dhcp4Dxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/Ip4Dxe/Ip4Dxe/DEBUG/Ip4Dxe.dll 0xF7FFF000
    Loading driver at 0x000F7FFE000 EntryPoint=0x000F7FFF59C Ip4Dxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/Udp4Dxe/Udp4Dxe/DEBUG/Udp4Dxe.dll 0xF7FF0000
    Loading driver at 0x000F7FEF000 EntryPoint=0x000F7FF059C Udp4Dxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/Mtftp4Dxe/Mtftp4Dxe/DEBUG/Mtftp4Dxe.dll 0xF7FE1000
    Loading driver at 0x000F7FE0000 EntryPoint=0x000F7FE159C Mtftp4Dxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/Dhcp6Dxe/Dhcp6Dxe/DEBUG/Dhcp6Dxe.dll 0xF7FD0000
    Loading driver at 0x000F7FCF000 EntryPoint=0x000F7FD05DC Dhcp6Dxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/Ip6Dxe/Ip6Dxe/DEBUG/Ip6Dxe.dll 0xF7FAA000
    Loading driver at 0x000F7FA9000 EntryPoint=0x000F7FAA5DC Ip6Dxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/Udp6Dxe/Udp6Dxe/DEBUG/Udp6Dxe.dll 0xF7F9B000
    Loading driver at 0x000F7F9A000 EntryPoint=0x000F7F9B59C Udp6Dxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/Mtftp6Dxe/Mtftp6Dxe/DEBUG/Mtftp6Dxe.dll 0xF7F8B000
    Loading driver at 0x000F7F8A000 EntryPoint=0x000F7F8B59C Mtftp6Dxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/TcpDxe/TcpDxe/DEBUG/TcpDxe.dll 0xF7F70000
    Loading driver at 0x000F7F6F000 EntryPoint=0x000F7F7059C TcpDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/UefiPxeBcDxe/UefiPxeBcDxe/DEBUG/UefiPxeBcDxe.dll 0xF7F58000
    Loading driver at 0x000F7F57000 EntryPoint=0x000F7F585DC UefiPxeBcDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/DnsDxe/DnsDxe/DEBUG/DnsDxe.dll 0xF7F46000
    Loading driver at 0x000F7F45000 EntryPoint=0x000F7F4659C DnsDxe.efi
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/HttpDxe/HttpDxe/DEBUG/HttpDxe.dll 0xF7F31000
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/NetworkPkg/HttpBootDxe/HttpBootDxe/DEBUG/HttpBootDxe.dll 0xF7F18000
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/Platform/ARM/Morello/Drivers/PlatformDxe/PlatformDxeSoc/DEBUG/PlatformDxe.dll 0xF7EEE000
    add-symbol-file /builds/morello/manifest/bsp/uefi/edk2/Build/morellosoc/DEBUG_CLANGDWARF/AARCH64/ArmPlatformPkg/Drivers/LcdGraphicsOutputDxe/LcdGraphicsOutputDxe/DEBUG/LcdGraphicsOutputDxe.dll 0xF7EE4000
    Thanks,
    Mostafa
  • Hi Mostafa,
    After checking on the shared logs I could see the following in the SCP logs:
    What I believe that the hang is properly because of the issue with the PCIe controller which has not been turned on as the stage where boot hangs in UEFI is actually followed by the PCIe enumeration and as evident from SCP, the controller is not on so it's in a wait queue, I guess.
    Few things to check from here:
    1. Can you check the power supplies if they are as per the guide?
    2. Any secondary media or any external device connected to the board via PCIe, CCIX or USB interface? If yes, can you please unplug everything and check a nominal boot if that takes you through the UEFI menu?
    3. If available, can you please try the same firmware on any board? We are not facing it currently on any of the other Morello boards.
    Thanks,
    Himanshu
  • Hi Himanshu,
    Sorry, I was a way for while.
    1. I am using the power supplier that came with the board
    2. No external devices connect to the board
    3. I tried on another morello board (although it's in a different looking case) and the firmware works fine
