Hi
Hope someone can help with a strange problem I am having with linux pure-cap as I cannot work out what I am doing wrong.
I am trying to mmap() a buffer, write some Asm code into into and then execute the code in the buffer by branching to an address inside this buffer.
Everything will work but any load or store with pre-indexing or post-indexing will cause the capability access register to be invalidated (tag goes to 0) as if I updated it with a non-capability value.
Here are some examples of what causes the problem (note - not real code just example operations):
STR X0, [CSP], #16 LDR C1, [C0, #16]! STP C1, C2, [C16, #-32]!
But these instructions would work ok, for example, i.e they would not invalidate the tag of the capability register used for addressing):
SUB CSP, CSP, #48 LDR X0, [CSP, #16] STP C1, [C0, #32]
The classic example is a fault on CSP because typically the compiler will give a "store registers to stack and decrement CSP" at the start of a function. What then happens is a seg fault when trying to use CSP after code returns from the mmap() buffer.
Here is a short, cut-down example to illustrate what I am doing:
static const uint8_t asmData[] = { 0xe1, 0x0b, 0xbf, 0x62, /* stp c1, c2, [csp, #-32]! */ 0xff, 0x83, 0x00, 0x02, /* add csp, csp, #32 */ 0xc0, 0x53, 0xc2, 0xc2 /* ret c30 */ }; typedef void(*FUNC_PTR)(); #define BUF_LEN 4096 int main() { uint8_t *code_buf = (uint8_t*)mmap(NULL, BUF_LEN, PROT_MAX(PROT_READ | PROT_WRITE | PROT_EXEC), /* PROT_MAX() */ MAP_PRIVATE | MAP_ANON | MAP_NORESERVE, /* Flags */ -1, 0); mprotect(code_buf, BUF_LEN, PROT_READ | PROT_WRITE); // Copy code into the buffer memcpy((uint8_t*)code_buf, asmData, sizeof(asmData)); // Make buffer executable mprotect(code_buf, BUF_LEN, PROT_READ | PROT_EXEC); FUNC_PTR fp = (FUNC_PTR)cheri_sentry_create(code_buf); // Run from buffer fp(); munmap(code_buf, BUF_LEN); return 0; }
What is wrong with the above?
If the code is running from an asm function built into my executable then all works fine.
Note: - other things I have tried:
My SW stack is v1.6 morello release. LLVM toolchain I am using was built from morello/dev ~1 month ago (I can provide the git commit hash if required). Silicon version of the morello HW, if required please advise what info I'd need to provide.
Hopefully it is just something I am doing wrong, as this problem is pretty much a showstopper for the work I am doing.
Pete
You need `FUNC_PTR fp = (FUNC_PTR)cheri_sentry_create((uintptr_t)code_buf | 1);` in order to get a capability that has the LSB set for C64. Otherwise when you do an indirect capability jump you'll enter A64 mode and your instructions will no longer be what you intend them to be. The instructions that you find are broken are the ones where they're just SP in A64, whereas the ones that work are the ones that are mode-independent (i.e. mean the same in A64 and C64).
Jessica THANK YOU SO VERY MUCH!!!! And thank you for such a quick reply, I had been stuck on this since Friday. Ahh, it's so obvious actually... yes that is exactly what was happening but I just could not figure out why I was no longer in C64... (how I didn't see that my asm function addresses all have the LSB set I will never know!)
feel stupid now but THANK YOU AGAIN I can now get back to what I am supposed to be working on!
