Mali-G52 OpenCL driver deadlocks on circular event dependencies (clFinish hangs indefinitely)
## Summary
I've encountered a deadlock in the Mali-G52 OpenCL driver when creating circular event dependencies between two command queues. The `clFinish()` call hangs indefinitely.
## Environment
- **Device**: Radxa Rock 5 Model B
- **GPU**: Mali-G52
- **Driver**: ARM Mali OpenCL driver (latest available)
- **OS**: Linux (ARM64)
## Reproducer
The following minimal C program demonstrates the issue:
#define CL_TARGET_OPENCL_VERSION 120
#include <CL/cl.h>
#include <stdio.h>
#include <stdlib.h>
int main() {
cl_platform_id platform;
cl_device_id device;
cl_context context;
cl_command_queue q1, q2;
cl_event e1, e2;
cl_int err;
// Get platform and GPU device (code omitted for brevity)
// ... standard OpenCL initialization ...
context = clCreateContext(NULL, 1, &device, NULL, NULL, &err);
q1 = clCreateCommandQueue(context, device, 0, &err);
q2 = clCreateCommandQueue(context, device, 0, &err);
for (int i = 0; i < 500; i++) {
printf("Test %d\n", i);
fflush(stdout);
// Create circular dependency
err = clEnqueueMarkerWithWaitList(q1, 0, NULL, &e1);
err = clEnqueueMarkerWithWaitList(q2, 1, &e1, NULL); // q2 waits for e1
err = clEnqueueMarkerWithWaitList(q2, 0, NULL, &e2);
err = clEnqueueMarkerWithWaitList(q1, 1, &e2, NULL); // q1 waits for e2
clReleaseEvent(e1);
clReleaseEvent(e2);
clFinish(q1); // <-- HANGS HERE on Mali-G52
clReleaseEvent(e1);
// cleanup...
printf("PASSED\n");
return 0;
  • Does it work if you call clFlush(q2) before calling clFinish(q1)?
    OpenCL doesn't track cross-queue dependencies so won't automatically flush q2.
    From the clFlush API docs (edited for clarity):
    To use event objects that refer to commands enqueued in a command-queue as event objects to wait on by commands enqueued in a different command-queue, the application must call a clFlush or use a blocking command that performs an implicit flush of the command-queue.
