Streamline annotation reset counter
Hi forum,
I am trying to use streamline annotation for 4 vkCmdDrawIndexed in my test application with indexCount argument of 440, 220, 220, 53 respectively.
Each drawcall submission is preceded with a sleep and annotation and queuewaitidle as below.
for (size_t cb = 0; cb < n_drawcalls; ++cb)
 VkSubmitInfo si;
 si.sType = VK_STRUCTURE_TYPE_SUBMIT_INFO;
 si.commandBufferCount = 1;
 si.pCommandBuffers = &command_buffers[cb];
 sleep(3);
 ANNOTATE_MARKER_COLOR_STR(ANNOTATE_GREEN, "Draw call start");
 res = device_table->QueueSubmit(queue, 1, &si, nullptr);
 device_table->QueueWaitIdle(queue);
 sleep(3);
 ANNOTATE_MARKER_COLOR_STR(ANNOTATE_RED, "Draw call end");
When I look at some counters like $MaliInputPrimitivesTrianglePrimitives, it seems to be a cumulative count after each drawcall showing 440, 660, 880, 933 (screenshot).
I was expecting it to be 440, 220, 220, 53 to match with the indexCount argument of the vkCmdDrawIndexed. Other counters like FMA, CVT are being reset after each drawcall (screenshot). Is this expected or is there any way to reset the counters before each drawcall?
