graphics analyzer launch failure for java.lang.UnsatisfiedLinkError
Hello all, I installed Arm Mobile Studio 2022.0 on windows 10 successfully, but launching graphics analyzer failed due to the following exception.
!ENTRY org.eclipse.e4.ui.workbench 4 0 2022-04-16 17:56:52.129
!MESSAGE Failed to evaluate: ReferenceExpression [definitionId=com.arm.mgd.ui.expressions.replayEnabled]
!STACK 0
org.eclipse.core.runtime.CoreException: Plug-in "com.arm.mgd.ui" was unable to instantiate class "com.arm.mgd.ui.propertytesters.ModelPropertyTester".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:206)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:923)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:246)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:63)
at org.eclipse.core.internal.expressions.PropertyTesterDescriptor.instantiate(PropertyTesterDescriptor.java:99)
Caused by: java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:204)
... 50 more
Caused by: java.lang.UnsatisfiedLinkError: 'com.arm.compilermanager.Compilers com.arm.compilermanager.CompilerManager.getCompilers(java.lang.String, java.lang.String, java.lang.String, java.lang.String, java.lang.String, int)'
at com.arm.compilermanager.CompilerManager.getCompilers(Native Method)
at com.arm.mgd.core.offlinecompiler.MidgardShaderCompiler.findPreferredCompiler(MidgardShaderCompiler.java:133)
at com.arm.mgd.core.offlinecompiler.MidgardShaderCompiler.<init>(MidgardShaderCompiler.java:99)
at com.arm.mgd.core.CoreInstance.<clinit>(CoreInstance.java:37)
at com.arm.mgd.ui.propertytesters.ModelPropertyTester.<init>(ModelPropertyTester.java:35)
... 55 more
Does anyone know how to resolve the above exception ?
