graphics analyzer launch failure for java.lang.UnsatisfiedLinkError
Hello all,
I installed Arm Mobile Studio 2022.0 on windows 10 successfully, but launching graphics analyzer failed due to the following exception.
!ENTRY org.eclipse.e4.ui.workbench 4 0 2022-04-16 17:56:52.129
!MESSAGE Failed to evaluate: ReferenceExpression [definitionId=com.arm.mgd.ui.expressions.replayEnabled]
!STACK 0
org.eclipse.core.runtime.CoreException: Plug-in "com.arm.mgd.ui" was unable to instantiate class "com.arm.mgd.ui.propertytesters.ModelPropertyTester".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:206)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:923)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:246)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:63)
at org.eclipse.core.internal.expressions.PropertyTesterDescriptor.instantiate(PropertyTesterDescriptor.java:99)
at org.eclipse.core.internal.expressions.TypeExtension.findTypeExtender(TypeExtension.java:100)
at org.eclipse.core.internal.expressions.TypeExtension.findTypeExtender(TypeExtension.java:133)
at org.eclipse.core.internal.expressions.TypeExtensionManager.getProperty(TypeExtensionManager.java:122)
at org.eclipse.core.internal.expressions.TestExpression.evaluate(TestExpression.java:100)
at org.eclipse.core.internal.expressions.CompositeExpression.evaluateAnd(CompositeExpression.java:55)
at org.eclipse.core.internal.expressions.AndExpression.evaluate(AndExpression.java:34)
at org.eclipse.core.internal.expressions.ReferenceExpression.evaluate(ReferenceExpression.java:74)
at org.eclipse.ui.internal.services.EvaluationReference.evaluate(EvaluationReference.java:74)
at org.eclipse.ui.internal.services.EvaluationReference.evaluate(EvaluationReference.java:100)
at org.eclipse.ui.internal.services.EvaluationReference.changed(EvaluationReference.java:94)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:108)
at org.eclipse.e4.core.internal.contexts.EclipseContext.runAndTrack(EclipseContext.java:346)
at org.eclipse.ui.internal.services.EvaluationService.addEvaluationReference(EvaluationService.java:239)
at org.eclipse.ui.internal.services.EvaluationService.addEvaluationListener(EvaluationService.java:213)
at org.eclipse.ui.internal.handlers.HandlerProxy.registerEnablement(HandlerProxy.java:209)
at org.eclipse.ui.internal.handlers.HandlerProxy.<init>(HandlerProxy.java:189)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.readHandlers(LegacyHandlerService.java:639)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.readRegistry(LegacyHandlerService.java:579)
at org.eclipse.ui.internal.Workbench$36.runWithException(Workbench.java:2361)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:36)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4735)
at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:94)
at org.eclipse.ui.internal.Workbench.initializeDefaultServices(Workbench.java:2355)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2793)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:646)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:557)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
at com.arm.mgd.ui.Application.start(Application.java:129)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
Caused by: java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:204)
... 50 more
Caused by: java.lang.UnsatisfiedLinkError: 'com.arm.compilermanager.Compilers com.arm.compilermanager.CompilerManager.getCompilers(java.lang.String, java.lang.String, java.lang.String, java.lang.String, java.lang.String, int)'
at com.arm.compilermanager.CompilerManager.getCompilers(Native Method)
at com.arm.mgd.core.offlinecompiler.MidgardShaderCompiler.findPreferredCompiler(MidgardShaderCompiler.java:133)
at com.arm.mgd.core.offlinecompiler.MidgardShaderCompiler.<init>(MidgardShaderCompiler.java:99)
at com.arm.mgd.core.CoreInstance.<clinit>(CoreInstance.java:37)
at com.arm.mgd.ui.propertytesters.ModelPropertyTester.<init>(ModelPropertyTester.java:35)
... 55 more
Does anyone know how to resolve the above exception ?
