I've installed Keil uVision5 IDE for STM32F103VCT6 controller. And also installed necessary Software packs. And have given license for this tool, but while adding the license, it is throwing error like "Tools.ini is not located"
After that I've tried to open Keil uVision IDE, but it is not responding saying that it is not working properly. Could anyone please give solution
Windows 7
Processor : Intel I3 @ 2.40GHZ
4GB RAM
32bit OS
Hi Kannan, what type of license are you using? Is it a single-user license (Keil license) or a Flex floating license? You need to launch uVision as Administrator in order to install a Keil license for example.Tools.ini is a required file to run uVision so it seems something corrupted the installation. It might be worth trying to re-install uVision if the installation is corrupted.
Alternatively you can raise a support case on http://www2.keil.com/support/silver so that our support team can look into the issue in more details.
Hope this helps.
Best Regards,Stefano
I've uninstalled and reinstalled again. After that I've tried to open Keil uVision5 as Admin rights. Still same issue persists. Now even to activate License, Keil uVision is not responding. Always same error window pops up as said earlier
It looks like there's a more serious problem.
I would suggest to open a suppor ticket with support as they might have further information to help you. I would also suggest to include your tools.ini file in the support case so that the team can try to reproduce the issue.
Could you help me where i can locate it. Seems I forgot :)
It's usually in C:\Keil\tools.ini (or replace "Keil" with your installation root directory)
www.keil.com/.../3577.htm
