Debugging memory issues ARM7, Keil µVision 4
I am having some issues trying to debug what appear to be some very strange behaviors. For example, we have:
static const char* LOG_FORMAT = "0x%02x,%.5f,";
and the pointer changes for no obvious reason. Sometimes to garbage, sometimes to other constant strings (or part of) defined elsewhere in the code. We also occasionally see the code jump to a different section which should not be running (State variable appears to change without being asked to). There are 2 or 3 common failure modes, and they appear to happen at random. It is a relatively large code base and adding or removing some sections changes the failure behavior (or removes it completely) even though those sections are NEVER referenced.
The best theory at the moment is that it is a memory related issue as we have been over all of the recent changes with a fine tooth comb, and the simple act of inserting sections of code to move things around appears to change or remove the behavior.
What are the best ways about debugging this issue or similar issues? Have found the debugger useful at times, and not at others (but that could be user error).
Further notes. ARM7, using Keil µVision 4 and the armcc v4.1 compiler.
0
