Dear All,Currently now I'm trying to undersatnd the relationship between startup_ARMCM3.s and gcc_arm.ld from Cortex-M3 of MDK5.the following codes are refered from Cortex-M3 of MDK5 example code.
1 //---startup_ARMCM3.s----------// 2 3 __HeapLimit: 4 .size __HeapLimit, . - __HeapLimit 5 6 .section .vectors 7 .align 2 8 .globl __Vectors 9 __Vectors: 10 .long __StackTop /* Top of Stack */ 11 .long Reset_Handler /* Reset Handler */ 12 .long NMI_Handler /* NMI Handler */ 13 .long HardFault_Handler /* Hard Fault Handler */ 14 15 .size __Vectors, . - __Vectors 16 17 .text 18 .thumb 19 .thumb_func 20 .align 2 21 .globl Reset_Handler 22 .type Reset_Handler, %function 23 Reset_Handler: 24 25 26 //---gcc_arm.ld----------// 27 ENTRY(Reset_Handler) 28 29 SECTIONS 30 { 31 .text : 32 { 33 KEEP(*(.vectors)) 34 __Vectors_End = .; 35 __Vectors_Size = __Vectors_End - __Vectors; 36 __end__ = .; 37 38 *(.text*)
I want to know how to interpret the both code.Especially, 1. at the line 33 of gcc_arm.ld, what exactly .vectors indicate the range on the startup_ARMCM3.s ?2. at the line 38 of gcc_arm.ld, what exactly .text indicate the range n the startup_ARMCM3.s ?3. what is the relationship between gcc_arm.ld (line 27) of ENTRY(Reset_Handler) and startup_ARMCM3.s (line 23) of Reset_Handler: ?
