General aspects using a Discovery Board with a STM32F407VG and uVision from Keil and SW4STM32 fon AC6
Hello, some time ago I started to play with CortexM4,
I bought a Discovery Board with a STM32F407VG in order to be programmed with uVision from Keil.
I am developing a project where the money is very restricted, that's why I was using a free licence from Keil.
Everything was working fine until I exceed the program size of 32KB(now I need to pay the license if I want to continue for this way).
I started to look for other option, and gnu-arm-none-eabi with Eclipse seems to be the answer.
The big problem are the peripherals: I need to use UART(to output message on debugging time using the famous "printf()") and SDIO to log some variables from different sensors that require I2C.
In general terms: what are the aspects that I need to consider when I switch those IDEs: from uVision to "System Workbench for STM32" known as SW4STM32.
  • «i marianojb and welcome to the community!
    The STM32F407 Discovery board is a great choice; a wonderful board, which I have as well.
    I'm using gcc with openocd myself.
    This is a setup without ilg's Eclipse, simply because I'm on a platform that does not work with any of the pre-compiled toolchains.
    Even if I'm not using Eclipse, I certainly will recommend it for anyone who is programming ARM devices.
    You can use the UART and printf as usual, but I'm not sure which program you will want to use to capture the debug output from your device.
    You could use a normal terminal program (I've written my own program for capturing debug output).
    As Eclipse has many features that I do not know about, it might already be able to capture and display output from the terminal; I'm hoping that ilg will chip in with some comments here.
  • Hi marianojb,
    You can also evaluate GNU ARM Eclipse. please follow the STM32F4 Blinky project and you'll learn how to blink the LEDs on an emulated DISCOVERY board.
    Since you are a test engineer, you might find useful to know that the project templates include support for full semihosting.
    I personally used semihosting and the emulator to develop the µOS++/CMSIS++ project (I guess 99% of the tests were performed on the emulator and on the synthetic POSIX platform, with extremely rare tests on the physical board).
  • Hi Jens, my firs approach was just installing gnu-arm-none-eabi and the run a simple example. It was working fine until I call function "printf()".
    "printf()" was redirected to USART6 on my DiscoveryBoard(it is working very nice if project is compiled under Windows using UVision IDE), By the time I took the same project and in order to built it under gnu-arm-none-eabi I got some messages from linker:
    "undefined reference to `_exit'"
    "undefined reference to `_sbrk'"
    "undefined reference to `_write'"
    "undefined reference to `_close'"
    "undefined reference to `_fstat'"
    "undefined reference to `_isatty'"
    "undefined reference to `_lseek"
    "undefined reference to `_read'"
    As I read, "printf()" make some system calls. In a Bare-Metal environment those function need to be implemented. At this moment I don't have idea how to do it and how to to test them.
    Do you have a reference wiah can help me?
    Thanks in advance,
    Mariano
  • Hi Liviu, I am getting familiarized with GNU ARM Eclipse, for the moment I am struggling with "printf()" and some function calls in order to write and read a MicroSD memory.
    I got an example project from "STM32F4 DSP and standard peripherals library" from a previous version. And it works fine if project is built under Windows with UVision , However if the same project is built under linux it is stuck
  • > I am struggling with "printf()"
    if you would follow my advice, and create the project using the F4 template, there would be no problem with printf, since the projects generated by GNU ARM Eclipse take care of these details.
  • Yes, that would definitely be the way to go; it's better than any of my suggestions.
    - marianojb, please mark ilg's answer correct.
  • marianojb, generally it is easier to start with a functional template, even if it does nothing more than a printf("Hello World"), and add you own code and possibly your preferred libraries, than importing an example created for a completely different build environment and fighting to make it work.
    jensbauer, thank you for referring to GNU ARM Eclipse pages; FYI, the preferred tutorial is the F4 blinky, not the old Hello ARM tutorial you are mentioning.
  • The problem is in your Makefile; you need to add a library, which provides those functions.
    Fortunately, I've read somewhere on the net, that Eclipse provides an easy interface to add libraries.
    From reading about Eclipse, I understand that it provides a way for you to receive the output from printf in the debugger.
    This is probably what you would prefer the most, so I'll refer to the official Eclipse page:
    Tutorial: Create a Hello ARM test project
    Tutorial: Create a blinky ARM test project (this is the correct project, not the above one)
    There's more here:
    printf() and scanf() with GNU ARM Libraries | MCU on Eclipse
    Alternatively, you can add your own libraries, that handles printf. This will require some editing, though:
    g. printf to USART1 - Learning Eclipse & ARM
    To add a new library:
    C/C++ Build > Settings > Tool Settings > > GCC C++ Linker > Libraries > Libraries (-l)
    Press the '+' button and add your library there.
  • I've corrected the link, so I won't be confusing people who have the same problem.
    "POSIX system calls via host" - do I understand this correctly ??
    If I do, then that is an absolutely awesome feature!
    Is it possible to open /dev/somedevice or a pipe or a socket ?
    -If it is, then it means rapid development of fun stuff!
  • Hi ilg and jensbauer thanks for the links, they really help me.
    I started with F4Blinky project and it worked very fine. I saw it implemented Hardware Abstraction Layer(_hal_) libraries.
    When I began with STM32F4, I based my work on a "Standard Peripherals Libraries" example. It is a point that I didn't mention before just to focus on the differences between IDEs and its compilers.
    I am not sure how many changes are required to change my code from using "Standard Peripherals Libraries" to "HAL". I have been playing with USART with no success for the moment.
    I am wondering if there is an example of F4 Blinky project using "Standard Peripherals Libraries"? or Can I change the current F4 Blinky project to "Standard Peripherals Libraries"?
    Thanks in advance,
  • > Can I change the current F4 Blinky project to "Standard Peripherals Libraries"?
    you certainly can.
    the StdPeriph library is like any other software, to add it to a managed Eclipse project you have to the classic steps:
    - create a new folder, like std-periph, and two sub-folders,  std-periph/src and std-periph/include
    - copy the sources to std-periph/src
    - copy the includes to std-periph/include
    - add std-periph/src to the Eclipse list of source folders
    - add std-periph/include to the Eclipse list of source folders
    - possibly add some symbols to the Eclipse list of symbols
    I guess you can have a project including both HAL and StdPeriph, as long as you initialise each peripheral properly.
    for an example project using StdPeriph, create a project with the F1 template.
  • I think I can make this very easy for you, but you may need to start over.
    First, I use ST's very nice initialization code generator CubeMX to get started.  It gets rid of the need to hand modify all of the Standard Peripheral Driver stuff and will give you a much quicker way to get other stuff running like a USB port console, after you get the UART version working.
    I use the SW4STM32 toolchain, Eclipse based, unrestricted, works fine.
    Start with a blinky program.  Just open CubeMX, select New Project, when the window comes up, change from the MCU to Board tab on the upper left and select the board you are using (DiscoF4 I think) and click OK at the bottom. All of the GPIO pins are already configured to talk to the LEDs so you just need to go to the Project menu at the top, select "Settings", enter a directory where you want your files, and a project name.  DONT FORGET to change the Tool chain IDE from the default "EWARM" to SW4STM32.  OK out of the settings then generate the code by either clicking on the "gear" icon at the top or select "Generate Code" from the same Project pulldown you just used for the project settings.
    When it's done, open SW4STM32. Open File->Import, from the window that opens select General->Import Existing Project. In the new window browse to the containing directory you used for the project in CubeMX, it should find your Blinky project and click OK.  Your priject should now show up on the left in the Project Explorer window.  Expand it out, look in the Src directory and double click on the main.c file.  Scroll down to the while(1){ clause, after the comment line /* USER CODE 3 BEGIN */ add the following two lines of code:
         HAL_Delay(200);
         HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_12);
    Save your changes, build the program, and right-click on the project name, select Debug As and Select AC6...
    Hit run and the green LED should blink.
    Now to do printf:
    Same process but on the first CubeMX screen once you have your project settings set, on the left column find one of the UARTs you would like to use and enable it as Asynchronous.  You can click the top tab to the Configuration view to check the baud rate.  It is probably set to 115k, you can change it if you like, but regardless you'll want to know what it is when you fire it up.
    Have CubeMX generate the code, import it the same way you did Blinky and you should be able to build it but it won't do much.
    First I would just verify that the UART works by using the ST HAL calls to talk directly to the UART.  If you are adding to you blink program and already have the endless loop with the Delay built in, just add the following line:
         HAL_UART_Transmit(&huart2, "Hello There World\r\n",19, 3000);
    Where the first parameter is the descriptor/handle that the init code created for you (near the top of your main() source code).  It may be different if you picked another UART, not 2 or it might ne husart2, just find it in the source code).  Next is the array of characters the HAL call will send to the UART and the next parameter is the number of bytes to send (I counted).  Finally the HAL call takes a timeout value in milliseconds of when to give up if things don't work.  I figure 3 seconds is ok for most cases.  You need to connect the Tx pin of the UART to a UART-toUSB dongle like the FTDI chip based boards from a million Chinese manufacturers, and open a terminal emulator program on your PC like TeraTerm (my preference).  Make sure you set the Serial Port settings to the right COM port for your dongle (you can find it in Device Manager) and set the baud rate to what you had in CubeMX.  You should see your message displayed over and over again.
    Once this is working it is a small step to get to full printf() support.  You just need to add one OS callback routine which the libraries will look for when printf is invoked.  The routine is int _write(int File, char *outstring, int len);
    Put the function declaration somewhere at the top of the file in an appropriate place (like where the comments say something like user private function declarations).  Then add at the very bottom of the file between the bracketed comments for USER CODE 4 this function:
    int _write(int FD, char* outstring, int len){
         while(HAL_UART_Transmit(&huart2, outstring, len, 3000) != HAL_OK);
         return len;
    The bracketing in the while clause makes sure that the HAL UART routine is ready for new data, and not busy.  The _write function is well defined and documented.  the first field is a device descriptor (number) indicating which open device this message is destined for.  Since we have only one output device we can ignore it.  The next two parameters are very nicely given to us by the printf() handler to be a formatted string and the length of the string.  The function is supposed to return the number of characters written in case there is an error (like you were writing to a file, not the console and the disk was full before you finished).  But if printf gets back the same number as it sent it is happy.
    That should do it.  If you want to get fancy later, you can use the Interrupt driven or DMA driven UART HAL calls but you'll need to enable them in CubeMX first.
    Have fun and let me know if it works for you.
    Aaron
