ROM Self-Test in MDK-ARM - Another Approach Sought
I'm in the process of porting my Flash memory check for STM32F0 from gcc to mdk. The gcc check follows a method similar to:
http://stackoverflow.com/questions/24150030/storing-crc-into-an-axf-elf-file
This is a great solution since beside the CRC calculation it only uses toolchain components that have seen a lot of testing and
require minimal knowledge about memory locations of segments.
The method that app note 277 follows requires knowledge of addresses and the use of srecord. Also the CRC is just appended
somewhere whereas using --defsym leaves it to the compiler where to store the CRC correctly and not to me to have knowledge
about the binary format of the output file.
I'm therefore attempting to port the method I'm using to mdk. For that I need an arm equivalent of objcopy and some means of assigning the
CRC value to a symbol during linking. If you could help me with that I would be glad.
Regards,
Kilian
