Hello there,
does anyone have experience with using the Keil MDK for cross-compilation to Cortex-R52 target? I've found a thread that is clearing the air a bit, that only R4 and M cores are fully supported ( how to write flash programming algorithm for cortex-r52 ).
But is that true for the packaged compiler toolchain as well? I'd think the same Arm (clang) compiler toolchain is used in both the Keil MDK and the Arm DS.
On another note, do you now of a(n) (free) evaluation version for the Arm DS? Or stand-alone Arm v6 compiler licensing? Could not find anything.
Thank you very much in advance!
Cheers,
Áron
