Keil MDK Licensing Error: Serial does not match product requested
Hi everyone,
I'm running into a licensing issue when building my project using Keil MDK Professional 5.42 with ARM Compiler 5.06 update 6 (build 750).
I've already activated my license using a valid activation code and confirmed that my µVision shows MDK-Professional. However, I keep getting the following error when I try to compile:
What I’ve already tried:
  • Restarted µVision after activation.
  • Verified that TOOLS.INI has:
    TOOL_VARIANT=mdk_pro
    FLEX_USE=0
    System Info
  • Keil MDK Version: 5.42
  • License Type: Activation Code
  • Compiler: ARM Compiler 5.06 update 6 (build 750)
  • Target MCU: ARM7TDMI (LPC2138)
  • OS: Windows 11
Appreciate any guidance or help — this is blocking my build. Thanks in advance!
