Hello!
When I use the Notepad++ and select a variable or function name, all same words are highlighted also.
See example screenshot.
This function I would like to have also in Keil Vision 5, but it is not working and I also don't find it in configuration options.
Is it possible and how?
Thanks!Martin
Thank you for this suggestion, but µVision's integrated Edit-Find (CTRL+F) feature helps locate matching entries:
Thanks for the feedback.
During code analysis, it helps to see the same variable in one view when all are highlighted.
With the find function, I can just jump to the next.
I understand, Martin. However, further improvements are not to be expected in µVision.
Ok, Thanks to clarify this
