when using the debugging program, is there a way to assign a "label" to a specific address?
i.e. address x:0x03FF = mylabel.
so I can call it later,
thank you
Fausto Bartra
That's not really something to be done in the debugger. It's a job for your source code.
Thank you for the reply.my problem is that I have two applications running on the same micro.
so I can not debug both at the same time (as far as I know).
so I need some "hook ups" to check my data.
thank you.
Fausto
Yes, you can. You just need to load both applications into one debug session. This can be done with the command
LOAD <OMF-file> Incremental
See for more details:
https://www.keil.com/support/man/docs/uv4cl/uv4cl_cm_load.htm
You can put the load command of your second application into a INI File which is then loaded automatically when starting a debug session.
