Build is suddenly failing
Following the line below is the entire output of the compile/link showing the failure
Build target is mbed LPC1768.
Using mbed-os 5.10.1 library
The build has worked for literally years and as recently as a couple of days ago.  No major changes made recently.
The error message indicates that "__asm___23_NanostackRfPhyAtmel_cpp_b3c216a9___Z10delay_loopj "  is an undefined symbol.
And that the undefined symbol is referenced in source file "../../build/mbed-os/components/802.15.4_RF/atmel-rf-driver/source/NanostackRfPhyAtmel.cpp"
In the file-list section of Keil, "NanostackRfPhyAtmel.cpp" has an indication "problem in this file",
The entire output of the compile/link showing the failure
Build started
Using toolchain ARM_STD profile {'ENV': {'ARMLMD_LICENSE_FILE': '8224@10.100.182.21:8224@10.100.106.178'}, 'PATHS': {'ARMC6_PATH': '/opt/ARMCompiler6.15.13/bin/', 'ARM_PATH': '/opt/armcc5_06_u6/'}, 'common': ['-c', '--gnu', '-O3', '-Otime', '--split_sections', '--apcs=interwork'], 'cxx': ['--cpp', '--no_rtti'], 'COMPILE_C_AS_CPP': False, 'NEW_SCAN_RESOURCES': True}
scan /tmp/chroots/ch-4e3777d8-f0ef-41b1-92f9-235d3ee8f062/src
scan /tmp/chroots/ch-4e3777d8-f0ef-41b1-92f9-235d3ee8f062/extras/mbed-os.lib
Configuration error: 'static_memory_defines' is not defined. <-- Have always gotten this
link irrig.LPC1768
Error: L6218E: Undefined symbol __asm___23_NanostackRfPhyAtmel_cpp_b3c216a9___Z10delay_loopj (referred from ../../build/mbed-os/components/802.15.4_RF/atmel-rf-driver/source/NanostackRfPhyAtmel.LPC1768.o).
Finished: 0 information, 0 warning and 1 error messages.
Internal error.
Build failed
Build failed
