Hello community,
I installed the Keil application on our tertiary machines using the admin account. During the installation, I was prompted to choose a location to store the ARM files, and the default location was set to C:\Users\IT Admin\AppData\Local\ARM. However, due to the policies applied to our machines, students are unable to access the C-Drive, which means they don't have permission to access the ARM folder.
To resolve this, we added the student groups to the ARM folder's security settings, granting them access. However, even with this change, the application still doesn't work when students try to launch it. Interestingly, if we launch the application as an administrator from a student account, it works fine.
Is there a way for students to access the application and its resources without requiring Administrator privileges, so they can use the application without issues?Please somene help?
Hi there, thanks for asking a question. I have moved your question to the Keil forum. If this is incorrect, please reply to this post.
Kabelo Motimele said:However, due to the policies applied to our machines, students are unable to access the C-Drive,
So I trust you installed them somewhere else, right. RIGHT?
The tools do not need admin rights to run, other than for installing licenses.
Can you explain exactly what error you see when you try to launch the tools?
