Hello there,
I already have a valid Licence for my MDK arm essential version but every time I got this error!
ARM C/C++ Compiler, 5.01 [Build 94] Error: C9932E: Cannot obtain license for Compiler (feature compiler5) with license version >= 5.0201203Cannot find license file. The license files (or license server system network addresses) attempted are listed below. Use LM_LICENSE_FILE to use a different license file, or contact your software provider for a license file.Feature: compiler5Filename: C:\flexlm\license.datLicense path: C:\flexlm\license.dat;FLEXnet Licensing error:-1,359. System Error: 2 "No such file or directory"For further information, refer to the FLEXnet Licensing documentation,available at "www.flexerasoftware.com".Cannot obtain license for Compiler (feature bsp_compiler5) with license version >= 5.0201203Cannot find license file. The license files (or license server system network addresses) attempted are listed below. Use LM_LICENSE_FILE to use a different license file, or contact your software provider for a license file.
Could somebody explain this please?!
Thank you!
I have moved your question to the Keil forum
If you possess a valid license, please open a new Support Ticket to get your request managed:
https://www.arm.com/support/contact-support
Arm Compiler 5 is a very old compiler.
To use this version, you must have a Professional Edition License:
https://developer.arm.com/Tools%20and%20Software/Keil%20MDK#Editions
Is it possible to use the supplied Arm Compiler 6 instead?
