Unable to redefine low-level library function
I am using the template from Redefining low-level library functions to enable direct use of high-level library functions in the C library (can get you code embedder to work)
namespace std{
struct __FILE
{ int handle;};
FILE __stdout;
FILE __stdin;
FILE __stderr;
int fgetc(FILE *f){
int c;
c = uart_read();
if(c =='\r'){
uart_write(c);
c = '\n';
uart_write(c);
return c;
int fputc(int c, FILE *stream){
return uart_write(c);
int ferror(FILE *stream){
return 1;
long int ftell(FILE *stream){
return 1;
int fclose(FILE *f){
return 1;
int fseek(FILE *f, long nPos, int nMode){
return 0;
int fflush(FILE *f){
return 1;
With the following header,
#ifndef __UART_H
#define __UART_H
#include "stm32f4xx.h"
#include <stdio.h>
// a whole load of function declarations
#endif
The compiler throws the following error,
error: redefinition of __FILE
struct __FILE
I using:
uVision V5.41.0.0
ArmClang V6.22
Target board - ST's NUF411RE
I have seen that this question has been posed before but the answer given in those cases was just to point to the Arm 5 to 6 compiler mitigation document
I cant find the solution to this in there.
