uvision 5 : can not printf "float"
I am working with the C8051F580 using a custom board.
I use UART0 to communicate with TERATERM. 115200 bps
I am using printf to send characters to TERATERM
for decimal printing works fine: printf ("%d",(samples[i]*5)/100);
but if I change it to float it displays "???" : printf ("%3.6f",(samples[i]*5)/100);
"samples" is unsigned int
any suggestion will be appreciated
Thank you.
Fausto Bartra
  • Try: printf ("%3.6f", (samples[i] * 5.0) / 100.0);
    or, depending on the expected range of "samples": printf ("%3.6f", (samples[i] * 5) / 100.0);
  • Rene:
    this works now, thank you.
    it is funny that you need to have "5 & 100" written as "5.0 & 100.0" for the compiler to work.
    Thanks very much
    Fausto
  • That's not so much "funny" as it is the way C works, and always did: operations on integers yield integers, so if it's floating-point output you wanted, you have to transition to floating-point at some point in the computation.
    It may well be a generally better plan to not involve floats at all, though, and instead allow the output to come without that decimal separator:
    printf("%9u", samples[i]*5);
    because surely, whatever is at the receiving end of that output has an easier time converting to floating-point data formats than a small, FPU-less 8051 derivative.
