I am working with the C8051F580 using a custom board.
I use UART0 to communicate with TERATERM. 115200 bps
currently I am using a simple routine to write to the terminal, see below. this works
void send_byte(unsigned char byte){ while(tx_busy); // Wait until tx queue is free tx_busy = 1; // Set uart tx busy SBUF0=byte; // Transmit byte}
But now I need to format text.
is there specific setting needed for the printf function to work
I have tried just sending printf("test \r\n") but I get nothing on the screen.
any suggestions will be appreciated.
Thank you
Fausto Bartra
