i am trying to compile keil project without using IDE and through just batch script and in that project c and c++ both files are there, i am using this command
armcc --cpp -c --cpu Cortex-M4.fp -g -O2 --apcs=interwork --split_sections -D__cplusplus -D__STRING_DECLS -I.\RTE\_dbg %CPP_INCLUDE_DIRS% -D__UVISION_VERSION=524 -D_RTE_ -DSTM32F479xx -o .\objects\test.o --list_dir .\\Listings\\ --list --omf_browse .\objects\test.crf --depend .\objects\test.d %SRC_PATH%\test.cpp
%CPP_INCLUDE_DIRS% -> group of include paths
%SRC_PATH%-> source path where all the cpp file are present.
test.cpp is a dummy cpp file, in that file when ever i am including header file include "string.h", it is showing this error "c:\Keil_v5\ARM\ARMCC\bin\..\include\string.CC(44): error: expected ';', near 'template'",
i have tried
-cpp11,
-cpp11 --cpp_compat
--cpp11 --strict
--cpp --gnu
--cpp --cpp_compat
test.cpp file
#include <stdio.h>#include "string.h" //after adding this header file i am getting error c:\Keil_v5\ARM\ARMCC\bin\..\include\string.CC(44): error: expected ';', near 'template
extern "C" int cov_dumpData(void);
void UTExit (void){ return;}
int main (void){ printf("\r\nhello\r\n"); if(1) { int res = cov_dumpData(); if(0) { printf("\r\nCoverage Error \r\n"); } UTExit(); return 1; } else return 0;}
can anyine help me, i just need to compile cpp files, though script , i am using keil MDK ARM 5.24.1, waiting for reply
