How do I to fix the issue? The issue is I have the file, but the Keil App can not find the file.
Help me!
Thanks.
HiMy name is Stephen and I work at Arm.If you have the Pack file, then I think you just need to import it. Use File > Import to import it. See:
https://developer.arm.com/documentation/101407/0540/Creating-Applications/Software-Components/Pack-Installer
Hope this helpsStephen
I see the same issue. This pack specifies a dependency on the pack "ADSP-SC83x_DFP" version 1.10.0 in its pdsc file. However, this pack seems not to be a public pack. You can only ask Analog Devices if they can provide this pack to you and to everyone. In the pdsc file, they specify their support address:
http://www.analog.com/en/support/technical-support.html
