dear,
I'm using arm compiler version 6.
when I build some codes as bellow, the compiler recognize "__GNUC__".
Could you let me know how not to recognize it?
What should I do for it?
Hi Ben,
the detection that CMSIS uses for AC6 is as below:
/* * Arm Compiler above 6.10.1 (armclang) */#if defined (__ARMCC_VERSION) && (__ARMCC_VERSION >= 6100100)
Hi Milorad,
It seems that my explanation was wrong.
I was asking why it detects "__GNUC__" even though I'm using AC6.
Could you help for it?
Thanks,
Your explanation was not wrong.
The Arm Compiler 6 defines the __GNUC__ define and the documentation says the following:
Always set. An integer that specifies the major version of thecompatible GCC version. This macro indicates that the compileraccepts GCC compatible code. The macro does not indicatewhether the -std option has enabled GNU C extensions. Fordetailed Arm Compiler for Embedded version information, use the__ARMCOMPILER_VERSION macro.
You can find the documentation about Arm Compiler 6 here: documentation-service.arm.com/.../65f99551b145b95232658cd9
So, you have to use different way of detecting if Arm Compiler 6 is used.
Appreciate.
