I'm using uVision 5 and wonder whether there is the possibility to get a list of symbols for a given module with their type and location resp. address offset.
In the Debugger's Symbols Window I can see the required information, but I don't see a possibility to simply save this table (csv would be perfect, but almost anything else would do also).
Exporting the memory range in question with the D command is possible, but I'm lacking the symbol names for the particular memory addresses.
Since I need to compare a few versions of a quite big struct with a ton of members that only brings me half-way to the destination ;-)
What I intend to do is something like this (example with a struct called data_hold):
etc...
Does anyone have an idea how to do that or already did a similar thing before?
I might not see the obvious after trying for hours without real success, please bear with me if the solution is actually plain to see :-)
Best regards
Stephen
