I have installed mdk539 version of keil uvision during package installation i am facing this errorE: the specified CMSIS Pack Root directory does NOT exist! Please take a moment to review if the value is correct or create a new one via `cpackget init` commandCannot download "www.keil.com/.../Keil.STM32F4xx_DFP.2.17.1.pack: General errorCannot download file www.keil.com/.../Keil.STM32F4xx_DFP.2.17.1.pack: General errori tried to solve it but its not working, and i am facing same error again and again
Hello, I'm not sure if there was a temporary issue with the server when you tried this, but it is working for me now.
You can also manually download the pack from the below, and install using Pack Manager > File > Import
https://www.keil.com/pack/Keil.STM32F4xx_DFP.2.17.1.pack
PS - I moved your query to the Keil specific forum
Okay, Thanks for responding, will try to manually download it
To understand the error about the not existing CMSIS Pack Root directory, you need to share a few more details about your system.
1) What tool are you using to install a pack?
2) Is there an environment variable called "CMSIS_PACK_ROOT" set and what is its value?
2) If you are using the the Pack Installer and it is open, what path is shown in the window title?
3) For the paths obtained in 2) and 3), do they exist on your hard drive?
