Hello all,
I am using UlinkPro with MDK5. I am getting a message in command line regarding "Cannot access Memory"
This message is popping up in Command window, while I am using Ulinkpro.
Can anyone please guide me why is this message popping up and possible way to solve it?
Thank you,
Regards,
Newton
I have moved your query to the Keil specific forum
This is hardly possible to guess. So you need to provide more details to understand, what goes on. Such details are:
1) What is the MDK version you use?
2) What device are you using and / or what is the memory layout of this device?
3) What data is placed at/around this address in your application (can be seen in the linker mapfile)?
4) One guess, does the message go away, if you close the "Call Stack + Locals window"?
Thanks for these insights, I will definitely try them out.
