I am new to 8051 and uVision.
I am able to get print to serial to work using register level code, but when I use printf the code goes into a hard run.
It is likely obvious to an experienced user so I am including a demo program below.
Note I am using a CAST 8051 core in an FPGA, and have 32K code and xdata rams.
Can anyone help?
#include <stdio.h>#include <reg51t.h>void init_serial0() { TH1 = (unsigned char) 250; PCON |= 0x80; // SMOD1=1 (double bit rate) TMOD = 0x20; // Timer1 in auto-reload mode TCON = 0x40; // Timer1 Run SCON = 0x50; // 8-bit UART Mode, Timer1-driven, REN=1}void wait(void) { unsigned int i,j,x; for(i=0; i<10000; i++) for(j=0; j<50; j++) x++;}void main () { PMOD = 1; // set GPIO out as push-pull P0 = 0; init_serial0(); printf("hello ..\n"); while(1) { wait(); P0 = 0x80; // led on wait(); P0 = 0; // led off }}
