how to declare the register R1 in my assembly code to R1 in the C source file to be able to use:
C-Program
extern void key_board(void); extern unsigned char R1; // ? main { .... if (R1 == 0x03) { ….. } .... }
Assembler-Code
NAME KEY_BOARD TASTEN_PORT EQU P1 ; benuetzter PORT P_ANZ EQU 03H ; Anzahl Portleitungen ;TASTATUR_MODUS BIT [0] ; Steuerbit fuer Modus (20.0) EINGAENGE EQU 00010111B ; Maske fuer Tastaturport: ; Tastaturpins = 1 ; unbenuetzte Portpins: ; Eingaenge : 1 ; Ausgaenge : 0 TASTEN_NUMMER EQU 01H ; Register 1 SPALTEN_ZAEHLER EQU 02H ; 2 ZEILEN_ZAEHLER EQU 03H ; 3 AUSGABE_MASKE EQU 04H ; 4 EINLESE_MASKE EQU 05H ; 5 ZAHLEN EQU 00H FERTIG EQU 03H LOESCHEN EQU 05H ?PR?key_board?KEY_BOARD SEGMENT CODE EXTRN CODE (c_func) EXTRN CODE (key_input) PUBLIC key_board RSEG ?PR?key_board?KEY_BOARD key_board: ;**************************************************************** TASTATUR: MOV A,TASTEN_PORT ; Pruefen, ob Taste noch ANL A,R5 ; aktiv ist JZ TADA ; Sprung, falls Taste aktiv SJMP WARTE ; Modus 0+1 : Taste wieder inaktiv TADA: SJMP KEINE_TASTE1 ; Modus = 1 : alte Taste noch aktiv WARTE: LCALL ENTPRELL ; Entprellzeit abwarten MOV A,TASTEN_PORT ; Pruefen ob Taste noch aktiv ist ANL A,R5 JZ WARTE ; Sprung, falls Taste noch prellt STARTE_ZYKLUS: MOV R4,#0FEH ; Startwert fuer Ausgabemaske MOV R1,#00H ; Startwert fuer Tastennummer MOV R2,#P_ANZ ; Startwert fuer Spaltenzaehler ...... RET END
Kind Regards
Juergen B.
Hi Juergen,
#include <absacc.h> // Register Bank 0 #define R1 DBYTE[1]
data unsigned char MYR1; // explicitly placed in DATA
In the ASM file, you refer to it by using EXTRN:
EXTRN DATA:BYTE(MYR1) . . . mov MYR1, #012h
I'm not quite sure what you're really trying to achieve, though. The compiler generates code it assumes to be best for the C you wrote. This is certainly not the same as the hand-written code by you, and you can't tell the compiler to do so. I tend to say: If you don't want to use C then, well, don't use it. Otherwise, write C and stop using assembly language for something as simple as debouncing keys. Use assembly language only directly where you have to or where the code generated really stinks.
JBaben said:how to declare the register R1 in my assembly code to R1 in the C source file to be able to use:
In a nutshell: you don't. In a mixed C-with-some-assembly program, you must generally assume that none of core registers of the CPU are free to use by your assembler code. The compiler needs them for its own work.As to the job this particular assembly function is meant to do for you, let's just say that the reasoning by which you decided at this is something you need, or even should do in assembler, is almost certainly flawed.
The Arm Compiler (and likely all Arm-based compilers) obey the Arm Procedure Call Standard.
https://github.com/ARM-software/abi-aa/releases
When a function is called, registers r0-r3 are used to pass parameters, and the return value is passed back in r0.
When writing asm code to work with C code, you MUST also obey this same standard.
You may wish to also see this Learning Path:
https://learn.arm.com/learning-paths/microcontrollers/efficient_embedded/
Apologies - I believe from other threads you are using 8051 class devices.
thanks for your advice.
I understood the thing with the assembler function in my C source file.
I will of course convert the assembler function to “C”.
But this is not just a simple function to query keys.
My function:
6 buttons should be queried via three port pins (with three diodes for decoupling).
Juergen
