Hello All,For the One of the project we are using the TLE9893 controller and Keil MDK5 environment.We have some specific requirement to create the noinit RAM Section to contain the variable value after Soft reset.we need help to create the noinitRAM Section in the keil environment.We are using Compiler Version 6.10.1 and DFP Package 1.0.0
Thank you
Hello Rohit,
It sounds like you are using this device:https://www.keil.arm.com/devices/infineon-tle9893qkw62s/features/
At first glance, it sounds like you are trying to do something similar to:https://www.keil.com/pack/doc/compiler/EventRecorder/html/er_use.html
Let us know if that article helps.
