Hi,I've got an older project which was formerly developed with Keil-µVision v5.26 and ARM compiler 6.16 (From Keil-µVision v5.36)This solution was chosen because the used debug probe ULINK2 did not work correctly in µVision v5.36 and it still seems to throw the same error in Keil-µVision v5.38.
To expand the project an mdk_essential license was bought.
This license now seems to work with the compiler v6.19 or Keil-µVision v5.38a but not with lower versions of the compiler.
Keil-µVision 5.26 with installed license results in:
- Linker (v6.16 toolchain): still complains about code size limitations (~32kB?) --> does NOT work as expected
- Debugger: does not show the warning regarding the code size limitation anymore --> works as expected (for programs < 32kB)
- Toolchain (v6.19): can not be used/installed for Keil-µVision 5.26
Keil-µVision 5.38a with installed license results in:
- Linker (v6.19 toolchain): links programs with larger code size as well --> works as expected
- Debugger: does not work with ULINK2 and MCIMX6X2:Cortex-M4 device --> Error Message is: "PDSC: Sequence Execution failed"
Is there either a way to
- convert the license to work correctly with Keil-µVision v5.26 or
- to make the Keil-µVision v5.38a/v5.39 work correctly with the debugger ULINK2 and device MCIMX6X2:Cortex-M4?PS.: the license is a flexLM (floating) license
Any help would be warmly appreciated!!!
Please raise an official support case from the support menu above, so that the appropriate contacts within Arm can address.
