I am currently in the process of installing Keil uVision version 5.15. During the installation, I need to configure the software to work with the Flex License Server. However, I'm encountering an issue where Keil uVision crashes immediately after I input the Flex License Server's address. This crash occurs without any error messages being displayed. Moreover, subsequent attempts to restart Keil uVision have been unsuccessful, as the program fails to launch again, not even from the command line it reacts.
Any insights or assistance in resolving this issue would be greatly appreciated.
Re-install Keil MDK 5.15 and compare the result.
Of course, it is required to consider upgrading to the latest release of Keil MDK, as V5.15 was released in May 2015.
Hi @rkopsch,
Thank you for your answer.Regarding the installation:I reinstalled it several times and the issue always repeat itself. The installation goes without any issue but when I configure the FlexLM License the program crashes. The address is correct and is the same as the colleagues of my team.
I took a look in the event-logs from windows and the following log was generated:
Faulting application name: UV4.exe, version: 5.15.0.0, time stamp: 0x55684ac4
Faulting module name: dcomutil_libFNP.dll, version: 11.12.1.0, time stamp: 0x53216679
Exception code: 0xc0000005
Fault offset: 0x001b5a07
Faulting process id: 0x45ac
Faulting application start time: 0x01da222e784e6681
Faulting application path: C:\Keil_v5\UV4\UV4.exe
Faulting module path: C:\Keil_v5\UV4\dcomutil_libFNP.dll
Report Id: b1e49fde-b7ea-432a-aa33-ed7726429fb9
Faulting package full name:
Faulting package-relative application ID:
Upgrading is unfortunately not an option.
