Hi all,
I am trying to build the DA14531 BLE SDK example from SDK6.0.16.1144. The prescribed compiler is version 5 [ARM_Compiler_5.06u7] which I have installed as per the instructions from Arm documentation. I have also activated a evaluation license key through the license manager. However when I try to build an example project it throws the following license issue
Build started: Project: ble_app_barebone*** Using Compiler 'V5.01 [Build 94] ', folder: 'D:\Vishnu_ancit\softwares\ARM\ARM_Compiler_5\Bin'Build target 'DA14531'assembling startup_DA14531.s...startup_DA14531.s: ARM Assembler, 5.01 [Build 94] startup_DA14531.s: Error: A9932E: Cannot obtain license for Assembler (feature armasm5) with license version >= 5.0201203startup_DA14531.s: Cannot find license file.startup_DA14531.s: The license files (or license server system network addresses) attempted are startup_DA14531.s: listed below. Use LM_LICENSE_FILE to use a different license file,startup_DA14531.s: or contact your software provider for a license file.startup_DA14531.s: Feature: armasm5startup_DA14531.s: Filename: C:\flexlm\license.datstartup_DA14531.s: License path: C:\flexlm\license.dat;startup_DA14531.s: Error: 2 "No such file or directory"startup_DA14531.s: For further information, refer to the FLEXnet Licensing documentation,startup_DA14531.s: available at "www.flexerasoftware.com".
Any help to fix this issue is deeply appreciated.Best,Vishnu
You mention Arm Compiler 5.06, but the build confirms Compiler V5.01.
Also, what Evaluation license did you activate?
How did you activate that evaluation license?
What tools are using to build your project?
And, confirm the exact versions in use of
- Keil MDK
- Arm Compiler
