Keil 4 allowed a function call in the idle loop which I utilized to generate how must time per second is spent in the idle loop
__task void os_idle_demon (void) { /* The idle demon is a system task, running when no other task is ready */ /* to run. The 'os_xxx' function calls are not allowed from this task. */ for (;;) { /* HERE: include optional user code to be executed when no task runs.*/ update_idle_time(); }}
//This called in Keil RTX os_idle_demon method which is when no other task or interrupts are running.void update_idle_time(void){ uint32_t dif, val; uint32_t irq_status = __get_PRIMASK(); __disable_irq(); val = usCPUTIMER; dif = val-last_idle_time; last_idle_time = val; __set_PRIMASK(irq_status); if (dif) { if (dif < 3) //If Counter only moves two or less then we must have only been in this task __atomic_add32(&idle_time_sum,dif); else __atomic_add32(&proc_time_sum,dif); }}
This is the output of a stat command using a Keil 4 applications.
You can see below we are keeping track of how many times a task is called, the Average, Minimum and Maximum Period and Execution Duration Stats.
We also have statistics on all enabled interrupts.
stat 10 | Period (us) | Duration (us) IRQ Name ID Count Flg Pri | Avg Min Max | Avg Min Max Last Start SysTick -- 0 01 9 500 0 0 0 0 0 (LEDs) TIMER1 2 2392850 03 19 1000 933 1067 43 41 112 2023/10/01,14:39:52.922 (Enc2) TIMER3 4 0 0b 2 0 0 0 0 0 0 (Mon) UART0 5 2 03 18 6667455 434 415817786 28 13 29 2023/10/01,14:39:52.855 (VE1) UART1 6 0 0b 6 0 0 0 0 0 0 (VE2) UART2 7 0 03 6 0 0 0 0 0 0 2023/09/12,10:18:42.620 (VE3) UART3 8 0 0b 6 0 0 0 0 0 0 RTC 17 2392 03 5 1000013 999987 1000040 41 34 63 2023/10/01,14:39:51.999 NMI 18 0 0b 0 0 0 0 0 0 0 2023/09/11,11:32:24.844 (Time) EINT1 19 11963581 03 1 200 198 202 20 19 22 2023/10/01,14:39:53.017 (Enc1) EINT2 20 0 0b 2 0 0 0 0 0 0 (Event) EINT3 21 0 0b 7 0 0 0 0 0 0 2023/09/11,11:32:24.832 ENET 28 226691 03 24 9889 15 106792 13 8 128 2023/10/01,14:39:53.047 (V/B/A) UART4 35 0 0b 6 0 0 0 0 0 0 GPIO 38 0 0b 18 0 0 0 0 0 0 ---------------------------------------------------------------------------------------------------- Task Name ID Count Flg Pri Avg Min Max Avg Min Max Last Start Init 1 5 03 0 0 0 0 1009616 1009437 1009623 2023/09/12,10:17:51.563 Timer 2 239304 03 130 10000 9932 10068 300 276 473 2023/10/01,14:39:53.111 File 3 23801 03 10 100220 99568 407107 232 28 307385 2023/10/01,14:39:53.038 Monitor 4 237948 03 0 10000 9538 314555 27 18 1413 2023/10/01,14:39:52.858 TCP 5 661775 03 50 3663 55 5520 79 29 1119 2023/10/01,14:39:53.153 Serial 6 26087 03 40 90738 61 101397 85 49 1091 2023/10/01,14:39:53.141 SPI UART 7 478619 03 60 5000 4931 5069 78 55 146 2023/10/01,14:39:53.176 HP Insp 8 1196555 03 150 2000 1920 2079 11 10 79 2023/10/01,14:39:53.190 LP Insp 9 478624 03 100 5000 4932 5068 15 13 77 2023/10/01,14:39:53.201 -
---------------------------------------------------------------------------------------------------- Total CPU Usage based off Idle Task Time in one second, Samples=10 Usage% Proc(us) Idle(us) Total(us) @ Time Dif Index Idle Int T2 T3 T4 T5 T6 T7 T8 26.9, 268762, 731252, 1000014, 14:39:44, 0.000000, 180, 91, 0, 3, 0, 0, 1, 0, 0, 1 26.9, 268522, 731492, 1000014, 14:39:45, 1.000000, 181, 83, 8, 2, 0, 0, 1, 0, 2, 0 26.9, 268707, 731306, 1000013, 14:39:46, 1.000000, 182, 90, 0, 3, 0, 0, 2, 0, 0, 2 26.9, 268596, 731443, 1000039, 14:39:47, 1.000000, 183, 84, 6, 2, 0, 0, 2, 0, 2, 0 26.9, 268720, 731268, 999988, 14:39:48, 1.000000, 184, 88, 2, 3, 0, 0, 2, 0, 0, 2 26.9, 268735, 731279, 1000014, 14:39:49, 1.000000, 185, 86, 4, 2, 0, 0, 2, 0, 2, 0 26.9, 268992, 731021, 1000013, 14:39:50, 1.000000, 186, 86, 4, 3, 0, 0, 2, 0, 0, 2 26.9, 268796, 731219, 1000015, 14:39:51, 1.000000, 187, 89, 2, 2, 0, 0, 1, 0, 1, 0 26.9, 269012, 731027, 1000039, 14:39:52, 1.000000, 188, 84, 6, 3, 0, 0, 2, 0, 0, 2 37.1, 371013, 628974, 999987, 14:39:53, 1.000000, 189, 78, 0, 2, 0, 13, 2, 0, 1, 0
I need all this functionality that is in the stat command to do troubleshooting at our customers sites.We try to test our custom software the best we can on the hardware we have available, but sometimes issuescan only be duplicated at a customer site.We can not plug in a pod to debug through the code. We meed to have all the tools needed for troubleshootingin the final application.We have a program logging system for high speed system file logs.We also have a logic analyzer that used the high speed capability of our FPGA to get traces and events to trigger on issues.
We are in the process of porting this NXP Cortex-M3 Keil 4 application to the STMicro Cortex-M7 Keil 5 application.
This is what I have at the moment for the stat command in the Keil 5 application.
I very much love that you now keep track of free stack space in all tasks.
Number of Threads = 7, ID=0x20010F68Idx=0, ID=0x20010F68, Name= cmdline_Thread, St=2, Size=2048, Space=1128, pri=24Idx=1, ID=0x20011430, Name= Idle_Thread, St=1, Size= 256, Space= 184, pri= 1Idx=2, ID=0x200114FC, Name= netEth0_Thread, St=3, Size=1024, Space= 512, pri=43Idx=3, ID=0x20010F24, Name= appmain_Thread, St=3, Size=1024, Space= 796, pri=24Idx=4, ID=0x20010EE0, Name= initmain_Thread, St=3, Size=2048, Space=1112, pri=24Idx=5, ID=0x20011474, Name= Timer_Thread, St=3, Size=1024, Space= 772, pri=48Idx=6, ID=0x200114B8, Name= netCore_Thread, St=3, Size=1024, Space= 728, pri=46
| Period (us) | Duration (us)IRQ Name ID Count Flg Pri | Avg Min Max | Avg Min Max SysTick_IRQn -1 0 0b 15 0 0 0 0 0 0 HardFault_IRQn -13 0 0b 0 0 0 0 0 0 0 BusFault_IRQn -11 1 0b 0 0 0 0 0 0 0 UsageFault_IRQn -10 3 0b 0 0 0 0 0 0 0 NonMaskableInt_IRQn -14 0 0b 0 0 0 0 0 0 0 (PWR) EXTI0_IRQn 6 0 0b 0 0 0 0 0 0 0 (5Khz) EXTI1_IRQn 7 20504 03 0 200 199 201 5 3 5 (Events) EXTI2_IRQn 8 0 0b 2 0 0 0 0 0 0 EXTI3_IRQn 9 0 00 0 0 0 0 0 0 0 EXTI4_IRQn 10 0 00 0 0 0 0 0 0 0 EXTI9_5_IRQn 23 0 00 0 0 0 0 0 0 0 (1ms) TIM1_UP_IRQn 25 4077 03 5 1006 999 1014 6 6 14 (Enc) EXTI15_10_IRQn 40 0 00 0 0 0 0 0 0 0 SDMMC1_IRQn 49 0 00 0 0 0 0 0 0 0 ETH_IRQn 61 71 03 10 70177 12 319147 10 9 19Cmd>https://community.arm.com/support-forums/f/keil-forum/32966/how-to-set-interrupt-priorities-in-cmsis-rtos-rtxBelow is quote from link above.
"the CMSIS-RTOS RTX kernel apparently does not disable interrupts explicitly. Instead, the atomic execution of critical sectionsis implemented as the SVC (Supervisor Call) exception, which runs at priority higher than any task."Keil sets SysTick to the lowest priority 15, but it uses the supervisor calls to do critical sections in the kernel.What is the latency of these critical sections. I need to know how much my 5Khz interrupt can vary. See data above it is Avg 200, min=199, max=201.Can we get access to add some small methods into the SysTick_Handler and All exception handlers.This is one implemenation that I did for the Hard_Fault.void HardFault_Handler(void){ /* USER CODE BEGIN HardFault_IRQn 0 */ startIRQTask(&bburam.IRQDataList[HARDFAULT_IRQ_NAME_IDX]); /* USER CODE END HardFault_IRQn 0 */ while (1) { /* USER CODE BEGIN W1_HardFault_IRQn 0 */ CIOB_HardFault_Handler(); /* USER CODE END W1_HardFault_IRQn 0 */ }}void CIOB_HardFault_Handler(void) { InFaultHandler = TRUE; uint32_t loop_count = LED_FAULT_LOOP_CNT; printf("\nException %s has occurred, Check CIOB_Fault.log...\n\n", reset_names[CIOBRST_HARD_FAULT]); while (1) { HAL_GPIO_WritePin(GPIOK, ALL_LEDS_MASK, GPIO_PIN_RESET); HAL_GPIO_WritePin(GPIOK, HF_LED_PATTERN, GPIO_PIN_SET); HAL_Delay(LED_FAULT_DELAY); print_dot(); HAL_GPIO_WritePin(GPIOK, HF_LED_PATTERN << 4, GPIO_PIN_SET); HAL_Delay(LED_FAULT_DELAY); print_dot(); if (--loop_count == 0) { break; } } if (bbu_ram_present) { LogFaultData = &BBR.HardFault_Handler_Data;#ifdef _INSP_CODE set_CatAlarmPin(DG_CPU_HARD_FAULT); proc_PLC_Outputs();#endif //_INSP_CODE } else LogFaultData = &LocalFaultData; LogFaultData->current_sp = __current_sp(); LogFaultData->ret_addr = __return_address(); LogFaultData->PSP = __get_PSP(); LogFaultData->MSP = __get_MSP(); save_fault_data(LogFaultData); memset(logMsgStr,0,sizeof(logMsgStr)); print_HardFaultData(LogFaultData, logMsgStr, sizeof(logMsgStr), TRUE, TRUE); printf("%s",logMsgStr); IncTimeStampCounter(&BBR.LifeCtrList[LCI_HARD_FAULT]); cpu_manual_reset(CIOBRST_HARD_FAULT); }Bottom line is I need to create a Windows Task Manager Prefomance tab for all active Interrupts and Threads.Any help to achieve this goal would be very much appreciated.Regards,David Petersenpetersen@filtec.com310-766-6319 Cell
Hi David Petersen,
why do you not reply in the support case you have opened about this topic?
