Hi all, I am using Keil uVision3 in my local laptop with license and I am trying to open .Uv2 file but unable to open the file. I am getting the following error " Cannot read project file". I am using windows 10 laptop. I request the community to help in this case. Moreover, the error is attached as follows. Thank you all.
You are obviously using MDK version 3.72. Do you know with which version of MDK/uVision this project was generated? You might see the compiler or linker version in old LST or MAP files. When you know the initial version, you could install exactly the same MDK version.
