I have a LPC2378 and LPC2478 on a legacy product that I inherited. Keil says on the website that Arm7 architectures are supported with the plus version. I have everything activated in uVision but the pack installer doesn't have any LPC2000 devices in the list. Am I doing something wrong or do I have the wrong product? The last engineer used uVision4 -- are these devices not supported in uVision5?
Thanks in advance,
Jordan
Hello Jordan,
Have you downloaded the (Arm7) legacy pack?https://developer.arm.com/documentation/101407/0538/Creating-Applications/Tips-and-Tricks/Use-MDK-Version-4-Projects
Regards, Ronan
Also, you require an MDK Plus or an MDK Professional license, see:
"Keil MDK v4 Legacy support: requirements"
https://developer.arm.com/documentation/ka005496/latest
Yes, I have the plus version and the arm7 legacy pack installed. Even still, I don't see any new options in the pack installer for setting up a project for a LPC2000 series uC
There is no Legacy DFP that the Pack Installer could offer.
The solution is to select the legacy device during project creation, see
I assume you:
- are using MDK v 5.38.
- downloaded the Legacy Arm Compiler 5 version r5p6-07rel1 from this page:
https://developer.arm.com/downloads/view/ACOMP5
- Added Arm Compiler 5 to the Keil MDK toolchain using these steps:
developer.arm.com/.../
- you downloaded and installed "Legacy Pack Download" "Arm7, Arm9, Cortex-R" (MDK79525.EXE) into the C:\Keil_v5 folder.
If so, then try opening these examples and see if you can load them onto to your evaluation board:
C:\Keil_v5\ARM\Boards\Keil\MCB2400\Blinky\Blinky.uvproj
C:\Keil_v5\ARM\Boards\Keil\MCB2300\Blinky\Blinky.uvproj
You can use those examples as a template for setting up your inherited project.
