Is there a roadmap for releasing Keil Studio Desktop as an alternative to uVision?
uVision's archaic API and build system makes it really difficult to integrate with modern pipelines. The only reasons I use uVision these days are create the initial project, and use the debugger.
If the VS Code extension could have a good debugger and access to the simulated devices to run on, that would be the perfect arrangement.
Thanks,
You can access MDKv6 Community Edition (for non-commercial use) now. See:https://www.keil.arm.com/
We cannot discuss future developments on this forum.I recommend to reach out to your Arm contact, else use the appropriate channel here:https://www.arm.com/company/contact-us/keil-support
Regards, Ronan
Ok, thank you sir. I will do it.
Thanks, I've seen MDKv6 and really like it. Do you have an idea when commercial licenses will be offered?
