I've got code in my project to dump out a data buffer using printf. STDOUT is redirected to the ULink2/uVision "Debug (printf) viewer".
It should produce output like this:
00000000: 00020400 00000000 5C0C0000 5C0C0000 ........\...\... 00000010: 5C0C0000 5C0C0000 5C0C0000 5C0C0000 \...\...\...\... 00000020: 5C0C0000 5C0C0000 C2030000 5C0C0000 \...\.......\... 00000030: 5C0C0000 B4050000 5C0C0000 5C0C0000 \.......\...\... 00000040: 5C0C0000 F4050000 5C0C0000 5C0C0000 \.......\...\... 00000050: 20060000 5C0C0000 5C0C0000 5C0C0000 ...\...\...\... 00000060: 5C0C0000 5C0C0000 5C0C0000 5C0C0000 \...\...\...\... 00000070: 5C0C0000 5C0C0000 5C0C0000 5C0C0000 \...\...\...\... 00000080: 5C0C0000 5C0C0000 5C0C0000 5C0C0000 \...\...\...\... 00000090: 5C0C0000 5C0C0000 5C0C0000 5C0C0000 \...\...\...\... 000000A0: 5C0C0000 5C0C0000 5C0C0000 5C0C0000 \...\...\...\... 000000B0: 5C0C0000 5C0C0000 5C0C0000 5C0C0000 \...\...\...\... 000000C0: 5C0C0000 5C0C0000 5C0C0000 5C0C0000 \...\...\...\... 000000D0: 5C0C0000 5C0C0000 5C0C0000 5C0C0000 \...\...\...\... 000000E0: 5C0C0000 5C0C0000 5C0C0000 5C0C0000 \...\...\...\... 000000F0: 5C0C0000 5C0C0000 5C0C0000 5C0C0000 \...\...\...\...
but what I get in the debug viewer is this:
0000 5C0C0000 \...\...\...\... 00000050: 5C0C0000 5C0C0000 5C0C0000 5C0C0000 \...\...\...\... 00000060: 5C0C0000 5C0C0000 5C0C0000 5C0C0000 \...\...\...\... 00000070: 5C0C0000 5C0C0000 5C0C0000 5C0C0000 \...\...\...\... 00000080: 5C0C0000 C8020000 5C0C0000 5C0C0000 \.......\...\... FFFFF00 ................
I suspect some form of overrun is occurring. If I step through the code I get all the output as I expect.Code:
void dumpHex(const void* DataPointer, size_t DataLength) { if (NULL != DataPointer) { char StringBuffer[100] = { '\0' }; const unsigned char* p = (const unsigned char*)DataPointer; unsigned char* pd; unsigned char* pa; size_t PointerSize = sizeof(void*); size_t DataOffset = (PointerSize * 2) + 2; size_t AsciiOffset = DataOffset + 38; size_t LineLength = AsciiOffset + 16; size_t index, i; int n; index = 0; while (index < DataLength) { pd = (unsigned char*)StringBuffer + DataOffset; pa = (unsigned char*)StringBuffer + AsciiOffset; memset(StringBuffer, ' ', LineLength); n = snprintf(StringBuffer, sizeof(StringBuffer), "%p", (void*)(index)); StringBuffer[n] = ':'; for (i = 0; (i < 16) && (index < DataLength); i++) { if ((i % 4) == 0) pd++; *pd++ = HEX[*p / 16]; *pd++ = HEX[*p % 16]; *pa++ = (' ' == *p || isgraph(*p)) ? *p : '.'; index++; p++; } printf("%s\n", StringBuffer); } } }
What do I need to do to ensure I get all the output?Thank you, David
I added 500ms delays between every printf() in the code and I'm still getting Trace: HW Buffer overrun and entire lines are going missing. Surely the ULink2 isn't *that* slow?
I even tried extending the delay to 1000ms (yes a WHOLE second) and the problem still occurs.
Puzzled, David
Hmmm This has to be a problem with the ULink2 firmware - I added every increasing delays to my code that sends the data on the ITM port and it didn't change the behaviour:
#define ITM_Port8(n) (*((volatile unsigned char *)(0xE0000000+4*n))) #define ITM_Port16(n) (*((volatile unsigned short*)(0xE0000000+4*n))) #define ITM_Port32(n) (*((volatile unsigned long *)(0xE0000000+4*n))) #define DEMCR (*((volatile unsigned long *)(0xE000EDFC))) #define TRCENA 0x01000000 FILE __stdout; FILE __stdin; int fputc(int ch, FILE *f) { microDelay(10); // wait 10us before sending character if (DEMCR & TRCENA) // Only if ITM is available { while (ITM_Port32(0) == 0); // Block until room in ITM FIFO ITM_Port8(0) = ch; // Write the data } return(ch); }
Anyone from Keil ULink team watching?
David
BUMP
Hello, this could be a baud-rate configuration issue.I'm not familiar with the particular device you are using, but you can measure the output rate of SWO pin with an oscilloscope, then set the SWO speed appropriately in Target Options > Debug > (ULINK2/ME) > Settings > Trace.
That makes a good deal of sense to me - next time I use ITM redirection I'll take a look at that.
Many thanks, David
