I am using keil with S32Kxx production based on "apnt 304"document.
As it mentioned in the document there is no problem using keil with S32K series :>>
but when I open an example in the Keil this message is appeared :>>
I add some more compiler through the project menu like compiler version 6.9 but the problem was not solved. The version of my keil is 5.38.
I do not know what I can do to solve this problem!
thanks
Where are you selecting the compiler? It should be in Options > Target tab, similar to the below:
I think there is not any difference.
You need to make the change for each 'Target'. Note that the current OpenSDA CMSIS-DAP target is not listed in the errors.
In fact, I do not use compiler version 5.06 at all, but this warning (or error) is displayed
The issue is that you have multiple Targets, and are rebuilding them all, and so this compiler selection must be made in each.
Select the different targets from the pull down. and make the change for each.
Alternatively, if you only build the current Target (F7), you will not see the errors.
You are right.The problem was solved and I learn something new, but there is another problem that some header files are available and some are not.As I know I did not delete these files!...
I cannot replicate this - is it due to the space in "keil packs" in the path?
It is interesting too, ALL files are in "E:\....." drive and are not in "D\:..."drive at all.
It seems that some files are missed and are not available in the main file that I downloaded..
What is the value of the environment variable CMSIS_PACK_ROOT? Is it pointing to the D drive?
